White Rodgers 3 Wire Zone Valve Wiring Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2015, 09:29 PM   #1
Rewards Points: 111
White Rodgers 3 wire zone valve wiring question
I recently hooked up an indirect water heater. I previously had (2) 3 wire, white Rodgers zone valves hooked up with no zone controller. I have (2) 2 wire thermostats.
Here is the wiring diagram for the wr zone valves
http://s3.supplyhouse.com/product_fi...structions.pdf
With the indirect, I got another wr valve and taco 3 zone controller so I could prioritize the hot water call.
http://s3.supplyhouse.com/product_fi...trolWiring.pdf
The problem is the taco zone controller only shows which terminals to connect to on taco valves
http://s3.supplyhouse.com/product_fi...5-brochure.pdf
So hooking up the t-stats are pretty straight forward, but in a little confused about how to hook up the valves to the controller
Any tips appreciated, thanks
JustinNY is offline   Reply With Quote
Old 11-30-2015, 04:33 AM   #2
An old Tradesmen
Rewards Points: 9,244
I don't know how you/they got 2 wire thermostats to work with 3 wire zone valves. Those valves are power open power closed. With a 2 wire thermostat, they should have always been open.
Old 11-30-2015, 06:10 AM   #3
Rewards Points: 111
Forgot to mention, there's a 24vdc transformer that was used for power. But the zone controller has its own transformer so I was going to just abandon it
Old 11-30-2015, 04:13 PM   #4
An old Tradesmen
Are you sure the zone valves were actually closing.
Post a pic of the wiring on one or both of the zone valves.
Old 12-01-2015, 11:42 AM   #5
Rewards Points: 111
I ripped out all of the wiring when I went to wire the controller in. Fortunately, I called Taco tech support and they have a cheat sheet for wiring non-taco valves. Will update for the archive if it works
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Question re: Heat Pump tsat wiring cwelte HVAC 10 10-05-2010 07:09 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
