Wheres Cold Water? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2017, 08:22 AM   #1
Rewards Points: 512
Wheres cold water?
Daughters main vanity sink doesnt have cold water. Its a Moen faucet, one handle.
Turned left there is hot water. Turned right it just shuts off, which is strange as this single handle usually comes on an shuts off by pulling up or pushing down.
Im thinking the cold water valve is shut off. Probably (based on rest of house plumbing) cause it leaks. I tried turning the valve but its rusted shut an I know forcing it will likely cause leaks.
Would there be another reason for not having cold water?
The vanity has a replacement floor base inside so therr has been water damage in the past.
Thank you
Startingover is online now   Reply With Quote
Old 01-15-2017, 08:42 AM   #2
JUSTA MEMBER
Rewards Points: 3,786
Re: Wheres cold water?
Replace the shut off valve.
It was leaking and the previous owner shut it off, and then it corroded over to ruin it.
Have seen it happen TOO many times.
They just replaced the floor to hide the fact that there was a leak, and hoped that the buyer would not realize that there will be needed work.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Startingover (01-15-2017)
Old 01-15-2017, 08:55 AM   #3
hkstroud's Avatar
Rewards Points: 6,694
Show us a picture of the inside of the vanity.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
Old 01-15-2017, 09:14 AM   #4
Rewards Points: 1,054
It could be many things. Start with the stop valve. Then the hose, which is unlikely. Last would be the cartridge/ports in the faucet. If you need to replace the stop valve, I'd go with a 1/4 one. If you go with a multi turn one, make sure you close and open it once a year to keep it from sticking and seizing. Brass Craft multi turn valves have cheap rebuild kits.
clarenceboddick is offline   Reply With Quote
The Following User Says Thank You to clarenceboddick For This Useful Post:
Old 01-15-2017, 03:57 PM   #5
Rewards Points: 512
Cleaning and lining this vanity I found 'another' puddle of water. Discovered a joint connection near the trap isn't sealed.
Interesting that theres another vanity on other side of the room and it doesn't have cold water either.
I made signs with problems, taped above each sink and told her she need a plumber not a mother.
Old 01-15-2017, 04:12 PM   #6
Property Mgt/Maint
Rewards Points: 8,202
Since you now have more than one faucet w/o cold, it's likely there is a branch line shut off valve that is closed. But is also likely closed due to a leak somewhere.
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 01-15-2017, 04:31 PM   #7
Rewards Points: 512
Yodaman.
Just curious. Since this is Florida and houses are on a slab, where would a branch line likely be? I haven't noticed any extra shutoffs in garage. Could they be outside?
This just happens to be the bathroom with the bad water hammer problem.
The smaller vanity has a bad bow near the bottom and visible water damage in the past.
Old 01-15-2017, 05:40 PM   #8
Property Mgt/Maint
Is there a utility closet in the area, maybe with a HW tank or heater? I wouldn't expect anything outside.
It could also just be that both stop valves are off under the vanities. Do you have cold water elsewhere in the house?
Startingover (02-03-2017)
Cold water over powers hot water. Loulicious Plumbing 12 03-04-2016 09:34 AM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
