Where To Find 1/2 Inch No Hub Coupling - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-27-2016, 05:15 AM   #16
Rewards Points: 12
Re: Where to find 1/2 inch No Hub Coupling
Thanks everyone
Sharkbites are applicable only for copper, CPVC and pex pipes. Galvanized Compression Couplings seems to be a solution of this problem, but I am not exactly sure whether it can use for unthreaded galvanized pipes in long term or not. Reviews are also very different. Some experts suggest it only for an emergency repair, but some others believe it can be use with no worries. Anyone has experience using these dressing couplings before?
mmdf20 is offline   Reply With Quote
Old 05-27-2016, 05:19 AM   #17
A "Handy Husband"
rjniles's Avatar
Rewards Points: 812
Originally Posted by mmdf20 View Post
Thanks everyone
Long term you should plan on replacing all of the galvy.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 05-27-2016, 09:06 PM   #18
Rewards Points: 352
I put one in a rental property ten years ago, still working.
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
mmdf20 (05-28-2016)
Old 05-27-2016, 10:20 PM   #19
Rewards Points: 12
Thanks for your reply
Is your pipes galvanized iron?
Could you please provide me a link or a picture of the coupling you used at your property?
Old 05-28-2016, 10:23 AM   #20
Rewards Points: 352
the link is in post 15
mmdf20 (05-29-2016)
Old 05-29-2016, 05:11 AM   #21
Rewards Points: 12
Thanks again
Sorry, I haven't check your user name. I doubted maybe it is another product that it shared here before.
Tags
coupling , plumbing
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
new 41/4 inch tile does not match old 41/4 inch tile sweet123 Flooring 2 12-27-2007 08:53 PM
24 inch to 16 inch Centers dsearles Building & Construction 3 11-30-2005 10:20 PM
