Where Did All The Power Cords Go? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2015, 11:35 AM   #16
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Ayuh,.... Nothin' can be seen in yer picture, it's 'bout all black,....
Electricity heats the water,....
Pipe head pressure moves the water,....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
gregzoll (12-10-2015)
Old 12-10-2015, 12:51 PM   #17
Rewards Points: 457
a better picture
Howz this? The cord from the round thing to the heater is about 4 inches; it's hard to see the cord, but it starts at the blue nipple coming off the blue round thing and runs to the the little white nub against the heater.
In the second picture, the line to the left of the round thing (that has dust hanging off of it) is a hard pipe that goes to the top of the tank, where all the plumbing and electrical connections reside.
Pipe head pressure = al2x oe9e naksusjl.
Does pipe head pressure rely on electricity?
If a plumber comes out and cuts the pipes and drains everything and turns off all that can be turned off and HAULS IT AWAY, and I turn on the cold water at the kitchen sink after he leaves, will I have my regular flow of cold water? Is the cold water flow independent of the hot water heater?
DIherself is offline   Reply With Quote
Old 12-10-2015, 12:54 PM   #18
Rewards Points: 457
here they are
Where did all the power cords go?-dcp_3941.jpg   Where did all the power cords go?-dcp_3940.jpg
Old 12-10-2015, 01:01 PM   #19
Super Moderator
joed's Avatar
Rewards Points: 31,580
Doesn't look like the plug is very accessible to be able to unplug it. I would just hard wire it and possibly move the box up to a more accessible place.
The Following User Says Thank You to joed For This Useful Post:
Old 12-10-2015, 01:02 PM   #20
ZZZZZ's Avatar
Rewards Points: 2,414
Photos no good. Ya need a flash.
ZZZZZ is offline   Reply With Quote
Old 12-10-2015, 01:50 PM   #21
Rewards Points: 457
here are better pictures, with a bonus picture of the tank (porcelain top removed). I'm still hoping a replacement WH can be installed with the existing electric and plumbing or I'm really in hot water.
Where did all the power cords go?-round.jpg   Where did all the power cords go?-roundplug.pipe.jpg   Where did all the power cords go?-tank.jpg
Old 12-10-2015, 02:12 PM   #22
Rewards Points: 127
That looks like and after market plug, that was not put on the water heater by the manufacturer .
It also looks like a 120 Volt plug .
jimn01 is offline   Reply With Quote
The Following 2 Users Say Thank You to jimn01 For This Useful Post:
gregzoll (12-10-2015), Wildbill7145 (12-10-2015)
Old 12-10-2015, 03:31 PM   #23
Rewards Points: 6,652
Yep. Not code Compliant. That outlet should have been placed higher.
Old 12-10-2015, 05:06 PM   #24
Rewards Points: 1,848
Looks like a 110 volt plug new tanks require 240 volts.
Old 12-10-2015, 05:15 PM   #25
Bondo's Avatar
Ayuh,... If yer on a well, the pump needs electricity to run to pressurize the system,....
On town water, Nope,....
Dependin' on how yer house is plumbed, 'n where valves were installed,...
Ya, the cold water should work just fine with the heater valved outa the system,...
If there's only one valve at the system entrance,...
Nope, ya gotta shut it All down,....
Be a good time to add valves to isolate things then,...
As noted above, yer gonna need an Electrician, as well as a Plumber,...
Might be a good time to find a better spot for the heater, 'n go to a 220v unit for efficiency,....
Probably cheaper for the heater,....
I've only seen heaters like yer's in house trailers,....
Old 12-10-2015, 05:15 PM   #26
Rewards Points: 5,424
Do the requirements I read above pertain to electric ranges and clothes dryers too?
SeniorSitizen is offline   Reply With Quote
Old 12-10-2015, 06:38 PM   #27
Dryers you usually find the outlets where the washer outlet is, for easy access when moving it.
Ranges cannot be easily moved, so you still find the cord or hard connection behind it.
It is an odd world that we live in, how some appliances can have the outlet behind them, others have them within reach, without moving or playing contortionist to get to.
Old 12-10-2015, 10:20 PM   #28
Super Moderator
joed's Avatar
The difference between washer,dryer and water tank is; washer,dryer are meant to be moved after installation. A water tank once installed is not meant to be moved. It has pipes connected to it.
Old 12-11-2015, 09:43 AM   #29
Rewards Points: 457
I can reach it -- just a couple of inches below the edge of the 36" top. I believe that plug location was well-thought-out. It would be unsightly to have it exposed all the time (higher up on the wall), even though it would be easier to reach.
The white tag taped to the tank (in the picture) says 240 with the other specs. The plumber taped the installation date of Jan 31, 1993 onto the tank also in the picture.
I am tempted to unplug it to look at the slots/holes in the wall, as I think those slots would be a better determinant -- better than the cover -- of whether it is 240 or 120, yes? as in:
Can a 240 plug be plugged into a 120 socket? Like if you went to get gas and tried to put the diesel nozzle into your gas tank, it wouldn't let you...
I could also unplug it and try to turn the cold water on and see what happens -- or doesn't.
Old 12-11-2015, 09:58 AM   #30
Bondo's Avatar
Ayuh,.... The power cord for the heater has to be higher than the heater, so water can't run down the cord, into the electrical box,....
As I said before, the power to the heater has NOTHIN' to do with the water pressure,...
Hot, or cold,...
gregzoll (12-12-2015)
Solar at the cottage? Tito1800 Home Theater 2 01-18-2012 02:30 PM
TV power bridge into existing outlet and protected by an external surge protector andytran73 Electrical 4 12-14-2011 08:00 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 09:43 AM
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
