Where To Cut Shower Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2015, 12:57 PM   #1
Rewards Points: 374
Where to cut shower drain?
Hello everyone. I've decided to replace a fiberglass shower pan with a mud set pan in our walk-in shower so I will need to put a new drain in. My question is, should I go ahead and cut the plumbing past the trap and replace all of it, or just cut right below the drain and re-use the trap. I haven't gotten a look at the trap yet, but it seems like I may want to put a new one in while I am there regardless. Thoughts?
costgeek is offline   Reply With Quote
Old 03-19-2015, 02:20 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,250
Ayuh,.... I guess I'd make that decision after I got eyes on it,.....
I don't replace plumbin', just because, but because I have to, to fit the new environment,...
Or,...
After ya see it, it might be a clusterf*#%, 'n needs changin' to make it Right,...
The Following User Says Thank You to Bondo For This Useful Post:
costgeek (03-19-2015)
Old 03-19-2015, 02:36 PM   #3
Rewards Points: 750
Drains are cheap. Even the expensive ones only run into about 40-50 bucks. I would just replace the whole thing, but settin eyes on it would help loads.
Hick is offline   Reply With Quote
Tags
drain , plumbing , trap
Best way to clean out shower drain? Pawl Plumbing 5 03-01-2015 11:27 AM
Adding new shower drain to toilet drain? w layout pics BNR34RB26DETT Plumbing 25 02-11-2015 09:55 PM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
