What Type Of Valve Is This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2015, 08:56 PM   #1
Rewards Points: 78
What type of valve is this?
I ordered a new dishwasher and I want to replace the valve from the hot water copper pipe since the current one is an old style and has corrosion on it. I want to replace it with a 1/4 turn valve. Anyway, I've attached a photo of the current valve. What type do I need to get to replace this fitting? I also want to replace the copper tube to the dishwasher with a flexible hose. What type of valve is this?-image-1805127014.jpg
scsiguru is offline   Reply With Quote
Old 01-12-2015, 09:02 PM   #2
Rewards Points: 582
you want 5/8 compression x 3/8 compression cp 1/4 turn ball valve like this...may even be able to shut off water loosen back nut remove valve leaving existing nut and ferrull on pipe install new valve...
The Following 3 Users Say Thank You to ben's plumbing For This Useful Post:
oh'mike (01-13-2015), SHR Plumber (01-16-2015), TheEplumber (01-12-2015)
Old 01-12-2015, 09:08 PM   #3
Rewards Points: 78
Thanks! Something like this?
Old 01-12-2015, 09:22 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 258
You want 3/8 on the outlet. Your picture appears to be 1/2"
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (01-12-2015), SHR Plumber (01-16-2015)
Old 01-13-2015, 05:57 PM   #5
Rewards Points: 1,942
5/8 by 3/8 compression valve 1/4 turn.
Make sure your dishwasher line is steel braided. Some heaters on dishwasher can melt through pex lines.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
samjg1 (01-15-2015), scsiguru (01-15-2015)
Old 01-15-2015, 08:25 PM   #6
Rewards Points: 78
Thanks everyone for ID'ing the valve. Stopped at my local big box store and picked one up.
The Following User Says Thank You to scsiguru For This Useful Post:
ben's plumbing (01-15-2015)
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 07:50 AM
Drain value dripping MsImmy Plumbing 11 01-29-2011 07:42 AM
what type of valve is this remopearl HVAC 4 01-03-2010 05:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
