What Type Of Pipes Are These? Polybutylene? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2016, 08:56 PM   #1
Rewards Points: 514
What type of pipes are these? Polybutylene?
I'm thinking about purchasing a new house. It was constructed in 1991, so I'm concerned about polybutylene piping. Is the clear piping a type of pex?
weatheredwood is offline   Reply With Quote
Old 08-03-2016, 09:00 PM   #2
Rewards Points: 1,948
Re: What type of pipes are these? Polybutylene?
That is pex. The other type your worried about is a grey solid colored pipe.
Ghostmaker is online now   Reply With Quote
Old 08-04-2016, 08:16 AM   #3
Rewards Points: 18,988
Interesting set up.
Around here we would have to have a disconnect where that armored cable is just running out of the wall.
http://www.homedepot.com/p/GE-60-Amp...0RCP/100674085
Could not use CPVC pipe for that relief drain line, main reason, you can not see if the valve is leaking or tripped.
That valve to shut off the incoming cold water does not look like a full flow ball valve.
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Never worked with steel/iron pipes cbzdel Plumbing 9 07-28-2011 10:18 AM
Draining water out of shower pipes docmattman Plumbing 9 05-23-2011 07:43 PM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 01:18 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 12:06 PM
