What Type Pipe For Well Drop Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By rjniles
  • 1 Post By rjniles
Old 06-12-2016, 04:37 PM   #1
Rewards Points: 306
What type pipe for well drop pipe?
Hello all. We just got a well drilled and the casing installed, and we're going to install the pump and pressure tank ourselves with the help of a knowledgeable jack-of-all-trades type who has done it before.
The well is 400 feet deep, and the water fills up to 20 feet below ground (I guess that means 380 feet of static head). The casing is 6 inch PVC. The pressure tank is going to be on a 30/50 psi switch.
The guy who has done this before suggests schedule 80 PVC, but the stuff is pretty expensive for that much pipe. My dad, who is a master plumber who now estimates jobs, says he has always used 1 inch polyethelene 160 psi for wells, but has hasn't done wells in a while.
What do you guys think? Am I ok with 1 inch poly 160 psi for this well?
eholmes77 is offline   Reply With Quote
Old 06-12-2016, 05:15 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 886
Re: What type pipe for well drop pipe?
HDPE (high density poly pipe) 200 psi. I would pump the well and see how far the level drops. This would tell you how deep you need to hang the pump. Also use a safety rope.
SHEPLMBR likes this.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
eholmes77 (06-12-2016)
Old 06-12-2016, 08:13 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,940
The poly pipe.
It comes in long rolls so no joints.
It is flexible so it can bend as you feed it down the casing.
Old 06-15-2016, 11:43 AM   #4
Rewards Points: 306
Would you go with IPS or CTS poly pipe? It looks like the CTS is a good bit cheaper at Home Depot.
Old 06-15-2016, 11:52 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 886
IPS has a controlled inside diameter and uses barbed fitting with SS brake band clamps. CTS has a controlled outside diameter and uses compression fittings. You want IPS.
eholmes77 (06-15-2016)
Tags
well pipe
Continuous Current on Water Pipe terps530 Electrical 263 04-11-2015 12:08 AM
Is this the right drainage pipe maddog1 General DIY Discussions 19 05-08-2014 08:46 AM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Copper pipe type for residential water distribution BigJimmy Plumbing 7 12-31-2007 08:39 AM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 07:53 PM
