What Type Of Fitting Copper Pipe To Plastic Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2017, 08:05 PM   #1
Rewards Points: 678
What type of fitting copper pipe to plastic softener
Replacing an old water softener with a Fleck 5600 and the supply lines for the control head are 3/4" plastic threads (see below). The water supply lines running to it are 3/4" copper.
What type of fitting(s) do I need to connect the plastic 3/4" MPT softener to 3/4" copper pipe?
dtbingle is offline   Reply With Quote
Old 08-13-2017, 08:11 PM   #2
Rewards Points: 6
Re: What type of fitting copper pipe to plastic softener
will this work? http://www.homedepot.com/p/SharkBite...12lf/202270645
paul100 is offline   Reply With Quote
Old 08-13-2017, 08:20 PM   #3
Rewards Points: 678
Originally Posted by paul100 View Post
Looks like it would! Thanks!
I was reading a few sites that said because plastic and copper expand and contract at different rates, there needs to be a rubber seal between the two to make sure no leaks would happen. Looks like that 3/4" FIP end has a rubber washer up in there and should keep it from leaking?
Old 08-13-2017, 08:25 PM   #4
Rewards Points: 6
yes, it should work fine. I have used it a few times
Old 08-13-2017, 08:26 PM   #5
Rewards Points: 678
Perfect, thanks for quick help!
Old 08-14-2017, 08:39 PM   #6
Rewards Points: 678
So I assumed the plastic male threads on the bypass valve were 3/4", but they are actually 1". Doesn't look like Sharkbite has a 1" female to 3/4" push-to-connect sharkbite copper.
What is my next best option?
Thinking either:
A) Contact the seller and get the 3/4" version that attaches to the bypass valve body
B) Find a reducer that's 1" female to 3/4" male - then the previous sharkbite hose would work. Looked a bit at the store and had trouble finding this size of reducer though.
Old 08-14-2017, 08:59 PM   #7
Rewards Points: 6
http://www.homedepot.com/p/SharkBite...24LF/203800359
The Following User Says Thank You to paul100 For This Useful Post:
dtbingle (08-15-2017)
Old 08-15-2017, 08:57 AM   #8
Rewards Points: 678
What the heck man, you have HD search voodoo magic. I did not see that when looking online and the guy in store at the plumbing section said they didn't make them lol. 13 in stock in my store.
Thanks again!
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Sweating a brass fitting to a copper pipe jgs1951 Plumbing 8 09-26-2011 09:06 PM
Copper Y fitting and cabinet install brneilly Plumbing 4 06-30-2011 09:13 AM
Copper pipe type for residential water distribution BigJimmy Plumbing 7 12-31-2007 08:39 AM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 07:53 PM
