What Is The Square Hole In Basement Floor? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By JustD
Old 02-21-2019, 09:04 AM   #1
Rewards Points: 12
What is the square hole in basement floor?
I'm planning on finishing my basement, but found a square hole in the ground with tube and water in it. It was dry before the snow storms. Not sure what's that for and if I can fill it up with mortar or cement.
Thanks in advance for any insight.
Pete
JustD is offline   Reply With Quote
Old 02-21-2019, 09:18 AM   #2
HenryMac's Avatar
Rewards Points: 762
Re: What is the square hole in basement floor?
Welcome to the forum JustD
Based on your comments......
There are drain pipes around the foundation of your home. If water makes it down to them they will dump that water into the hole.
If it's excessive you'll need to add a sump pump.
It's also an ideal spot for radon gas mitigation.
Where are you located.... and how old is the home?
HenryMac is offline   Reply With Quote
Old 02-21-2019, 09:24 AM   #3
retired framer
Rewards Points: 13,860
That is likely a floor drain connecting to the outside drain, but if you are getting water backing up from snow, you may want to deal with it before finishing the basement.
The wall in the back ground looks wet?
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 02-21-2019, 08:41 PM   #4
Rewards Points: 12
Henry, I live in Glastonbury, CT. The house is 33 years old with city sewer. I dont have sump pump in the basement. Sounds like this is a sump pit, but shallow.
HenryMac likes this.
Old 02-21-2019, 08:56 PM   #5
Rewards Points: 12
Neal, the wall near the hole is wet. the upper portion is dry but has efflorescence.
What is the square hole in basement floor?-square_hole-_basement_floor_1.jpg
Old 02-21-2019, 09:02 PM   #6
Rewards Points: 12
Do you think it might be a sewer cleanout? Thanks.
Old 02-21-2019, 09:23 PM   #7
Rewards Points: 1,502
No. Is that pipe open? Not capped on the end?
ryansdiydad is offline   Reply With Quote
Old 02-21-2019, 09:32 PM   #8
Rewards Points: 12
Two pipes, one black, another white. Both open and not capped.
Old 02-21-2019, 10:07 PM   #9
retired framer
Attachment 550889
You don't want to do any finishing until you get this figured out.
The out side of the foundation should have been damp proofed or waterproofed. The fix for that is to dig up the outside, correct the drain system and water proof the foundation.
Or dig up the inside, even if you have a drain on the inside you would need to manage the water that is coming thru the wall.
Like the picture that Henry posted but with a poly drape that directs the water under the slab to the drain.
So you are in for a lot of money or a lot of work.
Old 02-21-2019, 10:43 PM   #10
Rewards Points: 12
Thank you all!
Cutting sumnp hole in old basement floor CodeMatters Concrete, Stone & Masonry 11 12-25-2018 05:15 AM
Hw to fill hole in basement floor sumdumguy Concrete, Stone & Masonry 3 07-05-2018 10:21 PM
What is this hole in the basement floor?? kamkon Flooring 4 09-20-2012 12:53 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
