What Is This Pump For? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2017, 01:52 PM   #1
Rewards Points: 36
what is this pump for?
Hi,
I have a pump and bladder tank in my crawl space. Initially, i thought it was a sump pump to clear the crawl space of water but upon closer inspection it looks like a pump to boost water pressure. The suction and discharge would both be tied to the domestic water line. But either the suction or discharge (don't know which) is not connected so obviously not currentlyin use. And there is a pop valve sending water under ground to a drain i guess. Attached is the picture. is this for boosting water pressure?
thanks!
mufan is offline   Reply With Quote
Old 08-12-2017, 02:05 PM   #2
Big Dog
Drachenfire's Avatar
Rewards Points: 4,902
Re: what is this pump for?
I have seen a similar setup in a homes with a well. In that case it is used to boost the water pressure throughout the home.
Drachenfire is online now   Reply With Quote
Old 08-12-2017, 02:12 PM   #3
retired painter
Rewards Points: 50
I live on a hill with poor water pressure, when I bought the place it had a similar set up but the pump was busted [previous owner let it freeze]
mark sr is offline   Reply With Quote
Old 08-12-2017, 02:28 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,972
That is definitely a domestic water pump not a sump pump.
It is used either for pumping water from the ground well or boosting water pressure from a city line.
The outlet line does not appear to be connected.
Can't drain electric water heater dubina Plumbing 35 08-02-2017 08:07 PM
Circulator pump: guilty or not guilty? alight9010 HVAC 15 12-28-2015 08:43 PM
ejector pump suddenly tripping gfi lilargie Electrical 4 04-24-2012 05:15 PM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 10:51 AM
