What Manufacture?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2017, 11:48 AM   #1
Rewards Points: 97
What manufacture??
I am trying to replace my valve stems on my 1950s era tub/shower. Can anyone possibly identify this manufacture?
There is a "R" on the shower/tub diverter.
I am going to try to get the valve stems out but they are cemented in and have to be careful with any chemicals due to the fact we just got the tub and tile surround professionally refinished and do not want to screw up the refinish coating they put on. If anyone has any ideas how to loosen them without the use of chemicals, please let me know. Thanks in advance.
Centex2011 is offline   Reply With Quote
Old 01-01-2017, 11:54 AM   #2
JUSTA MEMBER
Rewards Points: 3,970
Re: What manufacture??
I've had luck with a DEEP WELL socket and a breaker bar.
ED
de-nagorg is offline   Reply With Quote
Old 01-01-2017, 12:02 PM   #3
Rewards Points: 97
Unfortunately, a traditional socket will not work because there are only two flat sides to grab on to (on the stem and on what I am presuming is the lock ring for the stem). I am thinking about going and borrowing a pipe wrench from my brother, although I don't know if even that will work.
Old 01-01-2017, 12:20 PM   #4
Rewards Points: 1,054
PB Blaster and a torch. You might be able to cut open a 1/2 drive O2 sensor tool, if the flats are the same size. Most O2 sensors are 7/8" or 22mm.
clarenceboddick is offline   Reply With Quote
Old 01-01-2017, 12:26 PM   #5
JUSTA MEMBER
What you have on that is the resurfacing agent.
I would get it's remover, and CAREFULLY use it on the fitting, using a small brush and paper towels to wipe it off.
If done carefully you won't touch the surround.
There appears to be something imprinted in the lower fitting on the first pictures, this might give you a manufacturer and #s.
That R might be the REGAL company, I think that they were around back then.
ED
Old 01-01-2017, 04:06 PM   #6
Use plastic and tape on that collar to keep the pen oil from getting on the tiles.
Help With Date Of Manufacture Jackofall1 HVAC 2 03-29-2012 06:37 PM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 02:40 AM
Manufacture date code for Bostitch RN 46 roofing nailer marvin81 Building & Construction 1 05-04-2011 03:53 PM
York JCI Manufacture ApprovedComfort HVAC 21 03-12-2009 07:53 AM
manufacture postal mailboxes yochi General DIY Discussions 6 06-11-2008 04:55 PM
