What Kind Of Sink Trap Adapter Is This (photo)? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree8Likes
Old 01-18-2018, 02:14 PM   #31
Rewards Points: 1,930
Re: What kind of sink trap adapter is this (photo)?
I would just purchase a new nut and gasket and not replace the trap adapter. If you replace it you will be making this into a major type job. It would even be helpful to see the gasket you currently have. Some trap adapters were 1.5 " with a 1.5 inch by 1.25 " gasket to the eye this gasket is a fat one.
Other trap adapters may be 1.5 inch to 1.25 inch with a 1.25 inch nylon gasket. The third choice is 1.5 by 1.5 if the chrome trap is 1.5 inch.
Old 01-18-2018, 04:38 PM   #32
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,834
Originally Posted by Sandywjo View Post
Great thank you, one last question. If I would decide to remove the old sink and Ptrap a few days before the new one gets installed, would it be safe to put a wet rag in the trap adapter to keep sewer gases from coming into the house? I know it could probably be capped off with an actual cap but if a wet rag is just as safe I will do that.
Originally Posted by hkstroud View Post
That should work just fine.
But it would be my personal advice.... don't use your wife's good dish towel.
MTN REMODEL LLC is offline   Reply With Quote
Tags
drain assembly , plumbing , trap adapter
Draining laundry sink into washer stack with trap in slab pkcinna Plumbing 19 08-17-2016 05:26 PM
kitchen sink disposal drain trap problem mystic_cobra Plumbing 20 04-13-2012 09:13 PM
trap adapter kyleraup Plumbing 2 11-08-2011 09:10 AM
Sink no longer draining after cleaning trap adnerbs Plumbing 3 11-18-2010 08:31 PM
cleaned sink trap, now i smell the sewer chrigarball Plumbing 1 08-16-2008 07:09 PM
