What Kind Of Continuos Water Heater System Can I Use To Replace My Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2015, 03:36 PM   #1
Lost..
Rewards Points: 354
What kind of continuos water heater system can I use to replace my water heater?
Over the last couple of months, I have been researching ways to reduce energy consumption. One of the things I hear mentioned on occasion is a inline water heater system or continuous heating system. I figured I'd ask the guys here that install these systems for recommendations, or advice on which way to look.
Right now I have one of the 100 gallon or so water heaters. It is about 2' in diameter and maybe 5-6' tall.
If I really can save money with a continuous system, what type should I look at and expect to spend?
J S Machine is offline   Reply With Quote
Old 12-01-2015, 04:48 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,038
Ayuh,.... Google up, "On Demand" water heaters,...
Mixed feelin's here, had 2, Great when they worked,....
The Following User Says Thank You to Bondo For This Useful Post:
J S Machine (12-01-2015)
Old 12-01-2015, 04:51 PM   #3
An old Tradesmen
Rewards Points: 9,224
Does your area have a lot of power outages? If so, keep in mind that a continuous/tankless will need power to give you any hot water. Where as a tank will have its gallons stored.
Old 12-01-2015, 04:59 PM   #4
Rewards Points: 18,794
May want to check out the cost to install first.
I most cases what you have there not for wiring or gas piping in not going to work and have to be all redone.
Factor that in, and the cost of having to have it back flushed about every year.
Old 12-01-2015, 05:20 PM   #5
Lost..
Rewards Points: 354
Can I not do it myself? For what it's worth, we don't have gas anything. If we ever did, I assume it would be propane, because we don't have natural gas piping. I'm not sure if natural gas can be stored in a tank?
Either way I was assuming an electric thankless system.
Old 12-01-2015, 06:55 PM   #6
Rewards Points: 2,174
If your water heater is currently located within your conditioned space, basement or other, then most of the heat that is lost is contributing to heating your home. Summer is the exception.
Heat pump water heaters would offer more in savings and reduce summer humidity and do some cooling.
In general, going from a large heated storage tank to an on demand system doesn't save a ton of money thus the money you would spend might yield better saving in other places.
Bud
Bud9051 is offline   Reply With Quote
Old 12-01-2015, 06:58 PM   #7
Lost..
Rewards Points: 354
Water heater is currently in the garage in it's own closet type room, which is not heated and cooled like then inside of the house. I'd assume it is also on the garage side of the fire rated sheetrock that separates the garage and house. It is wrapped in insulation about 1.5" thick.
Old 12-01-2015, 08:01 PM   #8
Do Check out the heat pump water heaters. In your warmer climate they should use half or less electricity. Have you determined how much your hot water is costing currently?
Bud
Old 12-01-2015, 08:22 PM   #9
Lost..
Rewards Points: 354
No I guess I need to get an amp clamp meter. I'm not sure exactly how to tell how much it is using. I have also never hears of a heat pump water heater.
Old 12-01-2015, 08:48 PM   #10
Rewards Points: 1,860
http://www.rheem.com/product/water-h...brid-heat-pump
Your state or local utility may have a program to encourage you to switch.
My hot water recirculation system is a disaster Michael Neill Plumbing 29 08-30-2019 06:15 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Water Heater: Replace or Not? AZSun Plumbing 4 08-25-2011 11:54 PM
