Is This What I Need For A Shower Only - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-26-2016, 07:14 PM   #1
Rewards Points: 80
Is this what I need for a shower only
http://www.deltafaucet.com/bath/deta...00-unbxhf.html
http://www.deltafaucet.com/bath/details/bt14296-ob.html
I want to replace a shower valve in my shower, no tub. Right now I have a handle to turn the water on and off, and adjust the temperature. I have a spot where the shower head comes out of the wall.
I can not make heads or tails of this thing. The valve has a bunch of cartridge looking things in the box . The other box has a brass body with a gray plastic looking cap thing. Compared to Moen this thing makes no sense at all. Please help
diymaster is offline   Reply With Quote
Old 06-26-2016, 07:55 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: Is this what I need for a shower only
Yes---you will need the valve body---(your first link) and the kit that contains the mixer cartridge and trims--
After you solder in the valve body---install the mixer cartridge----or your hot and cold water will mix--causing warm water to come out of the cold fixtures in your house.
Tiling pre-existing cement shower floor pan? KerryOn Kitchen & Bath Remodeling 3 07-14-2015 05:38 AM
General Questions w/ Pics on 1st Time Shower Pan Build/Install amodoko Plumbing 10 06-10-2015 02:45 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
