What Is This Corrosion From? Cellar Shut Off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2015, 01:04 PM   #1
Freedomsand's Avatar
Rewards Points: 304
What is this corrosion from? Cellar shut off valve
Looked up and noticed this valve has a build up of corrosion on it. To me, it looks like the acid build up we used to see on car battery terminals.
I think you can see the valve and the build up well in these photos. What does NOT show up as well is the "bulge" in the pipe. This pipe has never frozen (to my knowledge) and that is the only reason I know of for that sort of bulge.
This won't be a DIY project, but I would like to understand what is going on, and how to explain to my plumber what he needs to bring with him.
Oh, and usually my plumber LOVES to remove copper pipe and replace it with PVC. Not sure he can do that in this case? I guess there will be the new lever sort of valve installed.
This house is being prepped for sale, I have already moved out; in case that makes any difference to replies.
Thanks!
What is this corrosion from?  Cellar shut off valve-ri-pipe-1-.jpg   What is this corrosion from?  Cellar shut off valve-ri-pipe-2-.jpg   What is this corrosion from?  Cellar shut off valve-ri-pipe-3-.jpg   What is this corrosion from?  Cellar shut off valve-ri-pipe-4-.jpg
Freedomsand is offline   Reply With Quote
Old 06-22-2015, 03:34 PM   #2
Special User
Rewards Points: 1,230
Looks to me the solder joint has developed a slow leak. If the leak is slow enough, the liquid water evaporates and leaves behind mineral deposits. The bulge is probably just the way the valve was manufactured.
Copper can be replaced with CPVC, though I would consider it a bit of a hack job. I'd rather see a new brass valve soldered in or with compression fittings, personally. If he does install CPVC though, he needs to electrically bond the two sections of copper with a ground wire and clamps.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 06-22-2015, 03:48 PM   #3
Rewards Points: 18,960
Should have been a ball valve not a gate valve. Gate valves almost never shut off after a few years.
Someone left the flex on the fittings causing the corrosion.
PVC should never be used inside a house, copper, CPVC or Pex only.
tylernt (06-22-2015)
Old 06-22-2015, 04:35 PM   #4
Rewards Points: 304
My mistake . . . I do not know CPVC vs. PVC. No, the stuff he put in to replace copper was the right stuff. That was a job he did about a year back.
OK so I need to tell him to come prepared with a ball valve and copper piping to replace what is gone bad. Thanks.
Old 06-22-2015, 04:37 PM   #5
Rewards Points: 1,910
No need for a plumber. Just wash that off with a vinegar solution and your wife's toothbrush so it looks pretty. The bulge is the normal configuration of the valve body.
The Following User Says Thank You to jogr For This Useful Post:
Old 06-22-2015, 04:59 PM   #6
Rewards Points: 304
Being a single female, I don't HAVE a wife, lol.
Old 06-23-2015, 04:36 PM   #7
That's what happens when I try to throw some humor in. But no point replacing that valve if it's not leaking. Most buyers don't care what kind of valves they have and there is no reason to replace your gate valves before selling the place. They are very commonly used and perfectly acceptable. Good luck.
tylernt (06-23-2015)
Old 06-23-2015, 04:42 PM   #8
Rewards Points: 304
Ha haaa thank you. I will take an old toothbrush with me next trip there, and clean it up.
The Following User Says Thank You to Freedomsand For This Useful Post:
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Shut off valve replacement bates Plumbing 7 12-03-2011 10:19 PM
shut off valve behind toilet wont shut off Bunnypink Plumbing 5 04-20-2009 03:34 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Re-using compression nut and sleeve on another brand of shut off valve? DIYGST Plumbing 4 01-19-2009 12:44 PM
