What Is This Copper Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 3 Post By TheEplumber
Old 11-04-2016, 03:16 PM   #1
Rewards Points: 28
What is this copper pipe?
What is the copper pipe for? It's right next to a waste drain that drains two bathroom sinks one floor up. [I plan to drain a bathroom sink in the basement into it.]
I'm not too worried about it as the townhouse is 15 years old and it doesn't seem to have caused any problems but I'm curious (I hate unexplained artifacts in my house).
What is this copper pipe?-img_20161104_143710049.jpg   What is this copper pipe?-img_20161104_143722098.jpg
kbartels is offline   Reply With Quote
Old 11-04-2016, 03:45 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,348
Re: What is this copper pipe?
Heck if I know. Might have been the high pressure relief or something.
I would cap it just in case as you don't want sewer gases perking up.
Old 11-04-2016, 04:00 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 166
Based on the flattened top I'd say it was a make shift stake to hold the pipe in position as they poured the slab- been there, done that
Old 11-04-2016, 04:11 PM   #4
Rewards Points: 28
Ok. That makes sense as it was wrapped to the PCV with duct tape. I figured the tape was to keep the concrete off the pipes but, yes, I'll bet the tape was to keep the pipes together and hold the PCV in place.
Silly me. I use leftover rebar. Whatever's handy.
Thanks.
Old 11-04-2016, 04:12 PM   #5
JUSTA MEMBER
Rewards Points: 3,174
And if it is a stake, it is useless as a drain.
ED
de-nagorg is online now   Reply With Quote
Connecting PVC Sprinkler Pipe to Copper House Main Line fritzycat1 Plumbing 6 05-15-2013 03:25 PM
How to Estimate Water Flow Rate in Copper Pipe arskiracer Plumbing 12 04-15-2013 08:50 PM
Soldering copper pipe in tight location- Help Needed Pics included amodoko Plumbing 20 08-11-2012 04:14 PM
where do I set the black o- ring on the tub spout? or the threaded copper pipe? radioflyer77 Plumbing 1 07-05-2012 09:23 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
