What Is This Connection Called? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2015, 07:49 PM   #1
Rewards Points: 14
What is this connection called?
Can anyone tell me what this type of connection is called? It is the pipe that connects to my tub spout. I have searched online, but I cannot find any information. I purchased a "universal" tub spout at Home Depot, but apparently it's not 100% universal. This pipe appears to be 3/4 inch and made of brass(?). It's definitely not copper. The connection is not threaded but appears to push onto the old spout.
A photo is attached.
karenfromusa is offline   Reply With Quote
Old 04-08-2015, 07:57 PM   #2
Rewards Points: 18,964
Got a real mess there.
That whole corroded old steel nipple needs to come out, nothings going to work with what you have there now.
I'd be amazed if that old steel nipple will even come unscrewed, but if it does come out without breaking off replace it with copper pipe.
Old 04-08-2015, 07:58 PM   #3
Retired Moderator
Rewards Points: 7,174
that brass fitting is part of the old tub spout and need to be unscrewed from the steel pipe----
The steel pipe is really rusty so be careful----use two pipe wrenches--one to hold the steel pipe and another to unscrew the old brass fitting.
Some heat and maybe a penetrating oil may be needed to get that off.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
karenfromusa (04-08-2015), TheEplumber (04-08-2015)
Old 04-08-2015, 07:59 PM   #4
Retired Moderator
Joe was a little more blunt than me--but I agree--that one might turn into a real difficult job.
Old 04-08-2015, 08:02 PM   #5
Rewards Points: 14
I know. It's much more corroded than I anticipated. My house is about 50 years old, and I'm not sure when it was last replaced. There was no caulking around the spout where it meets the wall, so water was getting inside. Are you saying that the end, that sort of bumpy part, can be removed? I was thinking that, and I tried to see if I would unscrew, but it didn't budge, and I don't want to make a bigger problem by breaking the pipe. Thanks for the reply though.
Old 04-08-2015, 08:08 PM   #6
Rewards Points: 14
Thank you so much for all the quick replies! Now I understand. I was thinking it much need to be unscrewed. I have a heat gun, so I think I may try that. If it doesn't want to budge, then I will wait until I can call a professional.
Old 04-08-2015, 08:12 PM   #7
Just the joys of working with old steel pipe, it always rust out, the threads fail first, always leaves rust stains on the fixtures, almost always breaks off when trying to remove it.
Old 04-08-2015, 08:12 PM   #8
Rewards Points: 6,652
What will happen is that the minute you apply any kind of pressure, that pipe will turn into a pile of rust.
Old 04-08-2015, 08:23 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 248
Karen- probably the best approach is to put a pipe wrench on the brass piece and attempt to turn counter clockwise to loosen it.
Either the brass will come loose or the nipple will from the 90 inside the wall- which is ok.
There is a good chance that the nipple is the wrong length for your new spout anyways. It may need to be a touch longer or shorter.
If the nipple comes out, you can then calculate the length of a new one and screw it in using pipe sealant and teflon tape.
If it stays in and the brass comes off- go ahead and try the new spout for fit. Tape and dope all threads.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 04-08-2015, 08:27 PM   #10
Retired Moderator
That is why you need to use two wrenches---you do not want that pipe breaking inside of the wall----
Heat that up ( a torch is the best way) add some penetrating oil when it cools a bit---then heat again in an hour--get both wrenches out and give it a try---
EDIT---try Eplumbers method----I agree--that is a good way.
Last edited by oh'mike; 04-08-2015 at 08:29 PM. Reason: I like Eplumbers suggestion
Old 04-08-2015, 08:41 PM   #11
Rewards Points: 14
TheEplumber, thank you for another quick and excellent reply. I was thinking that also about the other end unscrewing from the main pipe, and then I could just replace the entire thing. Of all the home improvement projects I do, pluming makes me the most nervous. I have these wild fears that water is going to come bursting out and flood my entire house if I do something wrong. It scares me even more than electricity. I have learned a lot since owning my house though.
The Following User Says Thank You to karenfromusa For This Useful Post:
Old 04-08-2015, 08:43 PM   #12
Rewards Points: 14
oh'mike, thank you again. I don't have a torch, but they are pretty cheap at Walmart for a small one. I understand what you are saying completely. I'll go slow, and see what happens.
Old 04-08-2015, 09:15 PM   #13
Plumber
Rewards Points: 248
Thats the best approach- nice and slow- plan ahead for the "what ifs"
oh'mike (04-10-2015)
Range Electric/Gas Connection Master Brian Electrical 7 02-27-2015 09:07 AM
Outdoor receptacle near natural gas connection? cj133 Electrical 10 12-22-2014 08:04 PM
fix broken condensation line connection duhtroll HVAC 3 11-28-2014 05:57 PM
Dripping washing machine connection icespide Plumbing 4 11-11-2010 08:41 PM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
