What Is The Best Wrench For Opening A Outflow Drain Plug - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree38Likes
Old 05-27-2017, 07:56 AM   #31
Plumber
TheEplumber's Avatar
Rewards Points: 240
Re: What is the best wrench for opening a outflow drain plug
Originally Posted by Nik333 View Post
Both sinks drain thru the garbage disposal.
You have one sink with 2 compartments and they should not drain through the disposal
The Following User Says Thank You to TheEplumber For This Useful Post:
Nik333 (05-30-2017)
Old 05-27-2017, 12:14 PM   #32
Rewards Points: 6,228
Yes, I agree.
Nik333 is online now   Reply With Quote
Old 05-27-2017, 05:28 PM   #33
hkstroud's Avatar
Rewards Points: 6,692
I don't think that is possible.
Show us some pictures.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 05-27-2017, 06:22 PM   #34
I don't have a good way to add photos here.
The licensed plumber said he'd seen both sink "compartments" drain thru garbage disposal before. Everything is jury-rigged here.
Old 05-27-2017, 06:29 PM   #35
Btw, there is an old rusty open pipe outside & near the kitchen door, about 10 feet from the sink exterior clean out, that extends vertically about 12", full of dirty water & possibly a small amt. grease on top. That pipe is normally dry. What is that? What purpose? Thanks.
Old 05-27-2017, 08:33 PM   #36
hkstroud's Avatar
Surly you have a phone.
A photo taken with my Trac Phone. Uploaded to my computer using Bluetooth.
Harold,
Old 05-29-2017, 03:54 PM   #37
Rewards Points: 996
No and yes
I take a chisel to the brass ones. Knock out a chunk, then peel out the rest with channelocks
I had to remove 4" brass plugs. After using a 36" Ridgid pipe wrench without any success, except to ruin the square, I asked a plumber. He suggested putting the wrench on the square of the plug and hitting the soil pipe with a hammer. Worked!! Now I need to replace the brass plugs with mechanical pipe plugs. The threads have, over the last 122 years, have been lost. http://cherneind.com/Mechanical_Plugs/Default.aspx
MTN REMODEL LLC likes this.
fireguy is offline   Reply With Quote
Old 05-29-2017, 04:51 PM   #38
Oso954's Avatar
Rewards Points: 1,808
There's a lot of hair in this house, but how it gets in the kitchen sink, I don't know.
Easy answer is someone is washing their hair there.
It could also be that the hair is picked up by mopping and the mop or mop bucket got rinsed or emptied there.
Some of the laminate or carpet cleaners have dirty water reservoirs, emptying/rinsing them would have the same result.
Rainbow vacuum cleaner ?
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Nik333 (05-29-2017)
Old 05-29-2017, 07:22 PM   #39
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,830
When in my youth.... I've cleared a drain by dropping a cherry bomb down the vent and sittin on a 2x4 over the vent.
Not that I recommend.... but it was an emergency and a rental.....
Best
TheEplumber, de-nagorg and Nik333 like this.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Nik333 (05-29-2017)
Old 05-29-2017, 09:04 PM   #40
Best
I do hope you were very young. . . You could have lost your parts! When I was a child, a teen in the neighborhood put some dog poop & a cherry bomb in our car. After cleaning it, my dad sold it with the windows rolled down, on a cold day.
That wasn't you was it?
Old 05-29-2017, 09:09 PM   #41
Excellent point. Garden soil with tiny rocks, hair & fur.
I need a Roomba
Old 05-29-2017, 09:36 PM   #42
JUSTA MEMBER
Rewards Points: 3,762
Best
In my youth (17), I took an M80 and placed it in a soda can, with the fuse hanging out of the pulltab hole, lit the fuse and threw it as far as I could . About 15 feet or so, next thing I know that pop can comes flying straight back at me, and if I had not ducked it would have hit me between the eyes.
The things we do as foolish kids, it's a wonder we are still here.
ED
MTN REMODEL LLC and Nik333 like this.
de-nagorg is offline   Reply With Quote
Old 05-29-2017, 10:08 PM   #43
I'd never heard of this, so I looked it up. Does it hold dirt & water? I'd never pay that much for a vacuum, although, Miele is nice the way it dusts at a low suction. But, still too expensive. I'd rather have a better air purifier.
Old 05-29-2017, 11:51 PM   #44
ED
YEP.... and I still miss cherry bombs and M80's.
Edit (I'm just guessin it was lucky we were not friends back then... or we might not be here.)
Ever flush a cherry bomb down a movie theater toilet....?? (Probably get you in jail today)
de-nagorg likes this.
Nik333 (05-30-2017)
Old 05-30-2017, 12:00 AM   #45
Someone gave me one for protection. I put it in a big vase & forgot about it. I then moved from Hawaii to California. I would bet the movers never knew it was there!
Advice Needed to Replace Drain Clean-out Plug Perry401 Plumbing 6 01-21-2017 12:41 PM
Condo drain in upper unit caused drain in lower unit to leak? dangre Plumbing 15 07-09-2016 08:45 AM
Garage Floor 'drain plug' leaking into the basement below rockandroller Concrete, Stone & Masonry 8 05-02-2015 12:08 AM
Need an air compressor drain plug installed stewartlong Tools 4 12-10-2012 08:13 AM
bathtub drain plug rtyui2 Plumbing 2 04-06-2008 11:43 AM
