What Is This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2015, 09:41 PM   #1
Rewards Points: 442
Question
What is this?
Moved into a new home. This was behind an access panel in the basement. Can anyone clue me into what I am looking at?
clawlan is offline   Reply With Quote
Old 11-28-2015, 09:53 PM   #2
Rewards Points: 3,220
Water pressure reducing valve. (prv)
Make sure that area stays accessible in case repairs are needed.
jmon is offline   Reply With Quote
The Following 2 Users Say Thank You to jmon For This Useful Post:
BigJim (11-28-2015), oh'mike (11-29-2015)
Old 11-28-2015, 09:58 PM   #3
Rewards Points: 442
Ah. So this is likely the main line coming into the house? If I shut the bottom valve, I'm thinking that will shut off water in the house? I'm asking because I'm going to replace the stop valve under the kitchen sink.
The Following User Says Thank You to clawlan For This Useful Post:
Windows on Wash (11-28-2015)
Old 11-28-2015, 10:09 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,408
Mostly likely the main.
Be sure to find it on the street as well.
These gate valves get buggered and don't force it.
The Following User Says Thank You to Windows on Wash For This Useful Post:
clawlan (11-28-2015)
Old 11-28-2015, 11:21 PM   #5
Rewards Points: 442
Yea, it is really stiff when turning it. I might err on the side of caution and just shut off at the street instead.
Old 11-29-2015, 05:53 AM   #6
If you can sweat copper, I would replace that gate valve with a brass ball valve.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
jmon (11-29-2015), oh'mike (11-29-2015)
Old 11-29-2015, 08:50 AM   #7
I agree, should be replaced with a brass ball valve at some point.
However, you say it's a brand new home so it's probably just stiff and needs exercising. Try spraying some wd40 and work it off and on a couple times a year.
Looks like it got painted and that's what might be making it stiff. Just a suggestion.
Old 11-29-2015, 02:30 PM   #8
Rewards Points: 442
House is about 15 years old but the prev owners were very poor/lazy DIYer's and jacked up a lot of stuff. I'll hit it with some PB Blaster and see if that loosens it up at all. I can turn it, but it is really stiff.
Old 11-29-2015, 05:40 PM   #9
Yea, see if that helps any and clean the paint and drywall mud off the handle and stem.
If not, check the packing nut that's right under the handle and make sure it's snug but not too tight or over tightened. Sometimes if it's over tightened you won't be able to turn the handle very well either. Once you get it freed up, open it all the way then back it off (close it) just a little so it doesn't seize up like that again.
Or, as suggested, replace it with a full port brass ball valve. You would have to turn the water off at the street to replace it. If you go this route, check with your local municipality first to see who is responsible for this. Then it's just a matter of coordinating with them, you and your plumber when you want to do it.
Up to you. You will eventually have to deal with it sooner or later as those gate/globe valves never seem to work when needed. Just a suggestion.
