Wet Vent Vs Dry Vent - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By TheEplumber
Old 05-15-2016, 10:24 PM   #1
Rewards Points: 2
wet vent vs dry vent
a "plumber" said I have to put in a dry vent to move a sewer line. Not sure what he means,
docshandyman is offline   Reply With Quote
Old 05-15-2016, 11:14 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 170
Re: wet vent vs dry vent
Moved to plumbing board-
A wet vent is when a drain line serves as a vent for one or more fixtures. This can be either a vertical vent or a horizontal vent. Such as a bathroom lav that drains into the toilet vent (shares the same pipe)
Every fixture or trap requires a vent- wet or dry.
In your case, it sounds like you are moving a line that shares a vent with another fixture- so you need to add another vent to insure the altered work or the existing work is properly vented
docshandyman likes this.
The Following User Says Thank You to TheEplumber For This Useful Post:
docshandyman (05-16-2016)
Gas water heater vent too short? Ginny28 HVAC 6 05-04-2016 09:00 AM
Plumbing Book Reccomendations patrickpresti Plumbing 173 02-04-2016 06:15 PM
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
