Wet Vent Placement - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2016, 09:37 AM   #1
Wet vent placement
Hi,
I'm in the middle of a basement half bath drain plumbing and concerned about wet vent placement. Does the placement of the vent, before or after the toilet, make a difference? Would my setup in the attached photo be okay?
Josemq is offline   Reply With Quote
Old 05-31-2016, 04:50 PM   #2
Rewards Points: 1,866
Re: Wet vent placement
You can run toilet wet vent or wet vent then toilet Just size the wet vent properly.
Ghostmaker is online now   Reply With Quote
The Following User Says Thank You to Ghostmaker For This Useful Post:
Josemq (06-02-2016)
Old 06-02-2016, 08:12 PM   #3
Thanks for the reply..
The reason for my question is because I've actually already attempted to repipe this a couple times in an effort to get the proper pitch but it just isn't working out, my toilet always ends up to high(almost an inch above the floor). My original photo is what I was going to attempt to do, to swap around the toilet with the sink, to have the toilet closer to the main and maybe achieve a better pitch. The photo I'm attaching now is what I currently have. Debating now wether I should just build up the floor or something. What's normally done in this situation?Wet vent placement-img_0711.jpg
Thanks.
Old 06-02-2016, 08:38 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 186
Looks like a long turn 90 under the flange? If so, change it to a regular 90.
How about a street 90 or a street flange. Any of these will gain the inch needed.
Old 06-02-2016, 09:23 PM   #5
It is a regular 90.. I was thinking of maybe this flange with a 60 street? Is this a common situation? I wonder if this doesn't work, if it would be worth trying swapping the toilet and sink around or just building up the bathroom floor with some kind of cement board?
Old 06-04-2016, 08:34 PM   #6
Rewards Points: 76
hello josemq i see on the pic u have added a clean out pvc to ur waste line its 4inch correct? im trying to looking for two couplings that attach to the piece so i can add it to waist line like u did but the 4inch couping matches the piece it has to be a little smaller what sizes did u get
Sent from my SM-G900V using Tapatalk
charles3526 is offline   Reply With Quote
Old 06-04-2016, 08:43 PM   #7
What I added isn't a clean out, it's a half bath in the basement. But the main pipe I connected to with the couplings was 4" cast iron and the couplings were also 4"..
Old 06-04-2016, 08:49 PM   #8
Rewards Points: 76
thank you i have to go back and check i got the same one and the couplings are the same size of the piece i got and the three inch couplings are to small
Direct Vent Water Heater Question kc27 Plumbing 2 02-12-2014 01:39 PM
Installing new Vent pipe for kitchen sink dtweiss74 Plumbing 1 10-21-2012 02:11 PM
furnace cold air return vent placement flee HVAC 6 03-18-2011 12:06 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
