Wet Basement. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2016, 06:56 PM   #16
Rewards Points: 3,290
Assuming your description is correct, you must find and open up the far end of the drain pipe that extends away from the house. As long as the far end is covered over the entire drain system will back up to the house and cease to perform its intended function.
The sump with no drain pipes connected to it will protect the basement floor from flooding about five feet all around it.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 06-29-2016, 05:45 PM   #17
Rewards Points: 14
Re: Wet basement.
Ironically I found a clog in my gutter. I cleaned it out and haven't had any problems. But still no luck with the drain.
raidencmc is offline   Reply With Quote
My Basement Journey tojo78 General DIY Discussions 8 06-23-2017 07:53 PM
Insulation in basement ceiling for soundproofing -- will basement be too cold? jmai14 HVAC 3 11-16-2013 10:04 AM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
