Went To Change Wax Gasket, Flange Cracked! - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2015, 12:26 PM   #1
Rewards Points: 117
Went to change wax gasket, flange cracked!
This looks like a typical break right where the closet bolt goes.
House is 1991 built.
  • I can see what looks like purple primer on the pipes and seams--a little through the floor and also up through the kitchen ceiling (had to cut a 6x6" patch to inspect the drips that led me to this).
  • the "hole" looks like 3"
  • it also looks like someone re-did the bath after build as there appears (in the photos) to be grout dried over the actual flange in parts.
  • that makes me think i can't get a steel plate support under it.
I was planning on doing the entire bath in the Fall.
Is there any guidance without going into the floor heavily?
Went to change wax gasket, flange cracked!-img_3007.jpg   Went to change wax gasket, flange cracked!-img_3008.jpg   Went to change wax gasket, flange cracked!-img_3009.jpg
Dornier is offline   Reply With Quote
Old 06-02-2015, 01:30 PM   #2
Rewards Points: 3,430
Jb weld the broken piece may work as a quick temporary fix. Idk. Do you have access from underneath?
Others will be along with more advice/suggestions.
jmon is offline   Reply With Quote
Old 06-02-2015, 01:35 PM   #3
Rewards Points: 117
yeah, i can cut through my kitchen ceiling and get at most of it. I just didn't want to do any kitchen ceiling work. Been there already for a bad overflow on the tub.
Were I to do that, it sounds like I'd have to do this:
  • cut the drywall
  • saw the waste pipe
  • lift the entire flange and pipe out of the floor upstairs
  • put an entire flange, pipe, and PVC coupling down through the floor into the waste pipe.
I think i'm going to try to put a steel repair kit on it and see if that holds. the rest looks pretty snug. And, technically it only has to last until the Fall when I demo the bathroom and start over.
The Following User Says Thank You to Dornier For This Useful Post:
jmon (06-02-2015)
Old 06-02-2015, 05:21 PM   #4
Rewards Points: 1,932
Unscrew the flange from the floor.
Then with a screw driver and hammer Twist the outer flange.
You have two slots for tbolts other then the broken ones. Ones at 1 oclock and the others at 7 oclock on your close up pick.
Line them up directly across from each other as your toilet would sit. Measure off the wall to center of each to get them straight.
Screw flange into floor again.
Install new T bolts Get two sets so you can bolt the new tbolts to the flange slots securely with washer.
Install the toilet.
Have a beer.
Old 06-02-2015, 05:43 PM   #5
Rewards Points: 18,964
Good luck with those ideas.
The right way is to cut off the pipe below the floor, and install a new flange with a stainless steel flange and a tail piece with a new PVC tail piece and a hubless connector. (fernco)
Old 06-02-2015, 06:22 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 248
One more idea--all can be done from the top with no drywall damage.
Use an inside cutter in your drill and cut the riser pipe below the hub of the flange.
Glue a 3" coupling on the remaining stub. Then glue in a 3" street flange inside the the coupling. Align and anchor the flange, then set the toilet..
Tip of the day- stuff a rag in the 90 before cutting just in case the bit comes out of the drill.....
http://www.lowes.com/pd_285724-943-3...ductId=3234579
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (06-02-2015), jmon (06-02-2015)
Old 06-02-2015, 06:31 PM   #7
Rewards Points: 582
not just in case..every time we use that bit ...it falls out..
Old 06-02-2015, 07:32 PM   #8
My way will get him to fall. NAH NAH NAH!!!
Old 06-04-2015, 10:41 AM   #9
Rewards Points: 374
I ran into the same problem last year. I pretty much did exactly what ThePlumber has suggested. The tricky part is keeping the blade at a consistent depth so your cut is at a right angle to the pipe. Insert the cutter and choose a depth, then mark where the top of the opening is on the shaft of the cutter bit with some tape. Then just keep that tape level with the top of the hole as you cut.
After the cut, everything else went well. Make sure you know where you want your bolts to be before gluing it together!
costgeek is offline   Reply With Quote
Toilet tank leaking after gasket change Unicorn61 Plumbing 1 03-19-2014 11:07 PM
Cracked grout at change of plane; can I caulk over? Sloan Tiling, ceramics, marble 3 01-04-2014 10:09 PM
closet flange extension BlueBSH Plumbing 2 09-27-2012 09:58 AM
tile and toilet flange benshouse Plumbing 3 12-29-2010 06:02 PM
Sealant for neoprene flange gasket JakAHearts Plumbing 2 11-22-2010 02:48 PM
