Well Water Issues After Losing Power For 5 Days - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
Old 09-17-2017, 09:04 PM   #16
Usually Confused
lenaitch's Avatar
Rewards Points: 2,096
Re: Well water issues after losing power for 5 days
Originally Posted by Ghostmaker View Post
My guess is your water table has been compromised by the huge amount of water generated by the hurricane. I would not drink the well water. It can be used to flush toilets. You need to get it tested for bacteria. It may require a long time for the water table to restore itself.
Each well that was submerged in the flood feed water into your aquifer.
Excellent point. Your well might have been installed to the highest standards but every other well probing your aquifer is a hole.
SeniorSitizen likes this.
lenaitch is offline   Reply With Quote
Water tank T&P valve issues cynic Plumbing 3 06-23-2017 03:55 PM
Hot water cross over mystery maroonw Plumbing 4 04-29-2016 05:14 AM
Electric Water Heater Issues - Water Too Hot after tstat replacement and Sulfur Smell marman4880 Plumbing 4 08-05-2010 04:25 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
