Well Water Filtration Help Needed! - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 05-05-2016, 09:34 PM   #1
Rewards Points: 40
I have very hard water with iron and a bad sulfur smell
I currently use a Carbon Whole House Filter system from Lowes, it was cheap and does help.
I am worried a 44,000 Grain Softener is not good enough for my level of iron and hard water.
I want to use......| a system |.....and have perfect clean water.
ll81702 is offline   Reply With Quote
Old 05-06-2016, 10:12 AM   #2
Rewards Points: 18,772
Re: Well Water Filtration Help Needed!
http://www.lowes.com/projects/other-...-guide/project
ll81702 (05-06-2016)
Old 05-06-2016, 09:12 PM   #3
Rewards Points: 40
Originally Posted by joecaption View Post
Thank you!!!!!
Old 05-08-2016, 02:43 PM   #4
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Have you found out the flow rate from the well?
The recovery rate in the well?
Have you tested or had the water tested for the level of iron and hardness?
Softeners hardly NEVER Remove the H2S smell.
Akpsdvan is offline   Reply With Quote
Old 05-17-2016, 04:37 PM   #5
Rewards Points: 40
SO I turned the water heater up from 130F to 150F and the smell is almost gone
Also, the cold water doesn't have the smell at all.
Do I need a new water heater or a hot water whole home filter?
Old 05-17-2016, 09:15 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 1,734
I think I recently read in a post that a sulphur smell can sometimes be caused by a failed or failed sacrificial anode in the water heater (?), although I am also aware that it can come from the groundwater.
lenaitch is offline   Reply With Quote
Old 05-17-2016, 09:35 PM   #7
Rewards Points: 4,838
What gave you the idea to turn it so high? I know it kills sulfur causing bacteria, but also can cause full-thickness skin burns in 10 sec. I just burned myself badly with 160 degree water right out of the tap. I hope you don't have kids.
There are other options like chlorinating the well. Or a trial of it. Sounds like you need to test the water for bacteria, if the heat helped. Not an expert, but experienced in wells and burns.
Nik333 is offline   Reply With Quote
Old 05-17-2016, 10:39 PM   #8
Rewards Points: 1,854
Get a hydrogen peroxide water treatment unit.
http://www.waterdoctorjcgalloway.com...treatment.html
http://sflwater.com/hydrogen-peroxid...atment-system/
Old 05-18-2016, 12:00 AM   #9
Water Treatment
Akpsdvan's Avatar
I just do not see how your answers answered any of the questions that I posted.
Old 05-18-2016, 05:51 AM   #10
Rewards Points: 40
Flow Rate 10 GPM at the well head
Flow Rate 3 GPM after whole house filter
Cold Water tests negative for bacteria.
Hot Water tests negative for bacteria.
Hardness is 800+ ppm and iron is 5+ ppm as tested by home tester kit from Lowes.
The carbon whole house filter makes a noticeable difference in the water however it is not like i want.
As suggested by other forum members the hot water heater sacrificial element maybe bad? I do not know what this is but I have insurance on my water heater and will have it looked at asap.
Old 05-18-2016, 06:42 AM   #11
ZTMAN's Avatar
Rewards Points: 604
I had a horrible sulfer smell from well water at our hunting camp. Culligan installed a machine called Sulfer Cleer. Cost was $2,100 but it works
ZTMAN is online now   Reply With Quote
Old 05-18-2016, 07:49 AM   #12
Sulfur bacteria is an anaerobic bacteria. A hydrogen peroxide treatment unit adds the oxide increasing the O2 content of your water and eliminating the sulfur bacteria. Not to mention peroxide has the added benefit of causing iron particles to clump up for easy removal.
Nik333 likes this.
Old 05-18-2016, 08:29 AM   #13
Rewards Points: 40
So can I just poor a gallon of peroxide in my well?
But this is not permanent? I would like a solution that works permanently.
Old 05-18-2016, 09:04 AM   #14
Before or after the 150 degree temp?
Old 05-18-2016, 09:37 AM   #15
Rewards Points: 40
Both according to the home tests.
The Following User Says Thank You to ll81702 For This Useful Post:
Nik333 (05-18-2016)
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
