Well Pump Short Cycling - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2016, 06:47 PM   #1
Rewards Points: 4
Well pump short cycling
This morning I noticed my pump cutting on and off very frequently. After work I went under the house and the pressure gauge goes up to 60 then down to thirty very quickly and keeps doing it over and over. I found this piece leaking slightly, I have no idea what it is. COuld this be causing the short cycling? If so what is it and can I replace it myself. Thanks in advance.
greg8806 is offline   Reply With Quote
Old 07-26-2016, 07:09 PM   #2
Rewards Points: 18,790
Re: Well pump short cycling
Need far more info.
Well or city water, pressure tank?
Old 07-26-2016, 07:39 PM   #3
Rewards Points: 4
Sorry it is well water, the line comes in from well and goes to pressure tank, this valve is on the way to pressure tank.
Old 07-26-2016, 08:17 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,632
Is short cycling while the water is being or when taps are all shut?
Blower Fan Short Cycling ... Please Help! RealestWhiteBoy HVAC 24 05-13-2015 12:18 AM
Well pump short cycling Mark 8762 Plumbing 10 04-06-2015 01:14 PM
My oil burner is short cycling Richd820 HVAC 22 12-30-2011 12:20 PM
short cycling boiler repairguy Plumbing 0 08-15-2011 06:36 PM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
