Well Pump Running More Frequently - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By Akpsdvan
  • 2 Post By HenryMac
  • 1 Post By lenaitch
Old 02-26-2019, 09:10 AM   #1
Rewards Points: 200
Well pump running more frequently
My well pump seems to be running more frequently. I will hear it kick on when no water was used for several hours. Thanks in advance.
shocker is offline   Reply With Quote
Old 02-26-2019, 09:18 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,940
Re: Well pump running more frequently
Ayuh,.... Like yer other post,.... Not nearly enough info to base an answer on,.....
Bondo is online now   Reply With Quote
Old 02-26-2019, 09:27 AM   #3
Rewards Points: 200
I did some research online and my pressure tank appears to be fine. No water coming from the schrader valve and I checked the psi. The reason I post is that in the past when I lost power I would have water but this last time there was no pressure and the pressure gauge was at 0.
Old 02-26-2019, 10:47 AM   #4
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Pump runs for a short while then off then repeats?
Most likely a water logged pressure tank or the blander is shot.
Turn the pump off, drain the tank and see if water continues to come out and what the pressure is at the top of the pressure tank with tire gauge.
Could be the foot valve at the pump has a rock or something and will not close and it is letting pressure off when the pump stops.
Now go forth and trouble shoot.
HenryMac likes this.
Akpsdvan is offline   Reply With Quote
Old 02-26-2019, 10:53 AM   #5
HenryMac's Avatar
Rewards Points: 1,002
You'll only see water out of the schrader valve if the the bladder is completely full of water.
I had the same symptoms last year with our water tank. After weeks of accessing it in the crawl space and doing diagnostics we found the bladder had a very small hole. It would take a full day for it to change 2 psi. And 2 psi is the difference between "It's ok" and "It needs replaced".
We never did get water out of the schrader valve.... yet the bladder was slowly leaking.. ever so slowly filling with water.
Here's a link to more discussion on that, there's diagnostic video's and other such helpful stuff in the thread... https://www.diychatroom.com/f7/water...issues-641311/
Good Luck!
lenaitch and CFCPWN like this.
HenryMac is offline   Reply With Quote
Old 02-26-2019, 11:38 AM   #6
Rewards Points: 3,282
Possibly there is a leak causing the pump to run when no water is being used.
Old 02-26-2019, 12:33 PM   #7
Rewards Points: 200
No leaks inside the house that I can find. I drained the tank and checked the pressure and it seems fine. I thought maybe the check valve by the pressure tank might be bad but unsure.
Old 02-26-2019, 01:32 PM   #8
Water Treatment
Akpsdvan's Avatar
Was there 2 lbs less than the low number of the pressure switch?
You where also talking about the check valve at the pressure tank, if it and the foot valve are not seating then it will back drain into the well.
If the gauge is working at all it will lose pressure once the pump stops, might take a few minutes but it will drain back into the well.
Seems fine tells us nothing.
Old 02-26-2019, 02:07 PM   #9
Usually Confused
lenaitch's Avatar
Rewards Points: 744
This needs more clarity. If you had water with no power you were probably just using up the residual pressure in the tank. If you lose power and advertently or inadvertently use the water, it will draw it down to zero or darned close (it can happen just by muscle memory - like flipping a light switch during a power failure). If your foot or check valve is allowing pressure to bleed off, you would have noticed it before the lights went out.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 02-26-2019, 02:12 PM   #10
Rewards Points: 200
The pressure in the tank seemed fine. The idea of it draining back to the tank seems like a possibility. The check valve connects to the Tee and to the white plastic well pipe coming from outside. Thanks!
Sump pump cannot keep up with very heavy rains - please help rjlee Plumbing 32 02-03-2019 12:45 AM
Can't drain electric water heater dubina Plumbing 35 08-02-2017 09:07 PM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 04:56 AM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
ejector pump running constantly??? streetwise83 Plumbing 1 09-13-2008 09:37 PM
