Well Drill Running Constantly - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree8Likes
Old 05-21-2017, 06:46 AM   #16
Rewards Points: 898
Re: Well Drill Running Constantly
Originally Posted by beenthere View Post
Seen the old tanks only need air added once every several years. So its worth the OP giving it a try, instead of going out and buying a new tank right a way.
Read his original post. He called a pro and it only lasted 6 weeks. Said pro told him he needs to do it again. Call me crazy, I like having water available all the time. I like the ability to send the brown down. I can buy a tank locally for $200 and swap it out in 10 minutes. I bet he paid his pro more than $200. A well guy won't even show up in my area for less than $500.
BIG Johnson is offline   Reply With Quote
Old 05-21-2017, 07:03 AM   #17
hkstroud's Avatar
Rewards Points: 6,694
As stated, Aminius needs a new well man. Aminius also need to understand how a well tank works and then he won't need a well man. Note that this is just a galvanized well tank, not a bladder tank.
SeniorSitizen likes this.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 05-21-2017, 08:27 AM   #18
Rewards Points: 6,394
Originally Posted by arminius View Post
The well had been running (drilling) every time I ran water.
This is better than the old Sunday morning comics.
Yes, it is possible for a well to run every time you run water depending on how much water you run each time. And until you do a draw down test that's simple and costs close to zero, to determine if the pump starts with ever cup of water used or every 3 gallons used we have no idea whether your well system is actually screwed up or not.
Mike Milam likes this.
Old 05-21-2017, 12:54 PM   #19
An old Tradesmen
Rewards Points: 9,458
I'd rather call his well guy crazy.
Old 05-21-2017, 01:13 PM   #20
Rewards Points: 264
The draw is about 1 gallon.
arminius is offline   Reply With Quote
Old 05-21-2017, 01:36 PM   #21
The tank needs air again.
If this were mine I would pull the plug on top of the tank and replace it with a short nipple, 1"to1/4" bell reducer and a 1/4" valve. Air can conveniently be added there with compressed air or simply drain the tank allowing atmospheric air in through that 1/4" valve. Atmospheric air may be slightly more sanitary, but who knows for sure. I've done it both ways and still alive and grumpy as my wife says.
Old 05-21-2017, 02:44 PM   #22
Super Moderator
joed's Avatar
Rewards Points: 31,940
Looks to me like there is already a schrader valve under the pressure gauge. Just get a tire pump and pump some air into the tank.
Old 05-21-2017, 03:44 PM   #23
An old Tradesmen
Air pressure has to be checked and added after the tank is blown down.
Old 05-21-2017, 04:28 PM   #24
I missed that, and I bet you are correct.
If it is he can shut the power to the well and open a faucet until water ceases to flow then add air there at the schrader valve until the pressure gets to about cut off pressure of 55 or 60#. Wait a few minutes for the tank above water level to warm and he can once again determine water / air level by tank temperature difference at water level / air level by feel after the pump shuts off when power is resumed.
If water temperature and air dew point temperature is correct he will even see a condensation line on the tank.
I've added air to mine with both compressed air and gravity drain but my tank is at dirt level not in a basement and I have a hydrant down hill at the horse tank lower than dirt level at the pressure tank.
Old 05-21-2017, 05:25 PM   #25
Super Moderator
joed's Avatar
That is a capture air tank. There is no bladder. Pressure is zero when tank is drained down. Just pump some air.
Old 05-21-2017, 05:43 PM   #26
An old Tradesmen
Hence why I said it has to be blown down.
The Following User Says Thank You to beenthere For This Useful Post:
Yodaman (05-21-2017)
Old 05-21-2017, 05:45 PM   #27
An old Tradesmen
Air pressure has to be less then cut in/on pressure.
Old 05-21-2017, 06:04 PM   #28
I believe it will be if water ceases to flow. If the tank is in the basement I would think the only pressure remaining should be head pressure.
Old 05-21-2017, 06:19 PM   #29
An old Tradesmen
You don't pressurize the tank above the cut on pressure. If you do, then the first time you use water after refilling the tank. You end up getting a lot of air coming out of the faucet, until the air pressure drops enough for the pump to kick in.
Old 05-21-2017, 07:55 PM   #30
Super Moderator
joed's Avatar
It makes no difference how much air you add. Too much air will just blow out of the taps untill water comes.
Tags
holding tank , well service
Fan constantly running with Goodman CPLE30-1 Kast HVAC 0 07-25-2011 10:02 AM
Help with drainaige - Sump constantly running TANC Landscaping & Lawn Care 20 04-03-2010 11:15 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Bosch GSB 16 RE drill Coxy Tools 0 05-28-2009 01:46 AM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
