Weird Smell When Doing Laundry - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2018, 09:21 AM   #1
Jordan83
Rewards Points: 27
Send a message via AIM to jordan83 Send a message via MSN to jordan83
Weird Smell when doing laundry
So when doin laundry our laundry room smells.
Its only when or right after doing laundry.
The washer drains into the utility sink and the utility sink drains into the main line drain in the room.
Any ideas before I call the local plumber ?
Its done this for a while and wasnt bad but now it smells terrible.
The drain goes out to what looks like a sewer lid in my backyard.
That drains out to the sewer system.
jordan83 is offline   Reply With Quote
Old 02-03-2018, 09:31 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,528
Re: Weird Smell when doing laundry
Does the sink have a ptrap? Is the washer a newer top load without the large agitator? If so you may need to run it through a "clean" cycle with one of the Refresh products.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 02-03-2018, 09:32 AM   #3
Rewards Points: 88
Assuming here the sink drain has a trap under it ? And how often does this sink that is being drained in to, with soiled washer water...get cleaned ?
Gregsoldtruck79 is offline   Reply With Quote
Old 02-03-2018, 09:40 AM   #4
Peace be with you
DR P's Avatar
Rewards Points: 1,860
what is under lid in back yard?
septic tank, pump tank or something else?
where is smell appear to be originating; in sink?
if you slowly pour 8 oz of water in laundry tub drain
after washing cycle complete, does the smell stop in sink?
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Horrible Smell After First Load of Laundry XinnKoda Plumbing 9 02-23-2016 07:41 PM
Ductwork Deodorizer Chris Sweeney HVAC 28 01-23-2014 11:15 AM
Septic smell in laundry room McTibbetts Plumbing 0 06-13-2012 08:47 PM
Weird smell coming out of my bathroom drain? trailmix Plumbing 4 08-30-2011 12:49 PM
Weird Smell In Room fpproperties Plumbing 5 07-10-2009 10:36 AM
