Watts N250 Pressure Reducing Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2016, 11:10 AM   #1
Rewards Points: 4
Watts N250 pressure reducing valve
I'm looking to rebuilt my WattsN250 and I've got a rebuilt kit. When I opened the valve up I got this (see photo). That's rust, hard and crusty. Before I spend the time to chisel this out and try to free the old cartridge assuming that will work. Was hoping for some advice here before I go this route. I'm assuming the valve is brass so the rust must have come in from the street.
johnsonsmith is offline   Reply With Quote
Old 07-15-2016, 12:15 PM   #2
Civil Engineer
Rewards Points: 5,246
Re: Watts N250 pressure reducing valve
I would replace the entire valve, easier than trying to rebuild.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
jmon (07-15-2016)
Old 07-15-2016, 03:30 PM   #3
Rewards Points: 4
Actually seems these are iron body. So maybe the rust is from the valve itself? It's a substantial amount make me wonder if the integrity of the valve would be in question if I try to repair.
Old 07-16-2016, 12:27 AM   #4
Rewards Points: 1,526
The brass screen also corrodes to the body that it was easier to buy 2-3 and use universal joints. I think there is another brand with stainless steel screen, but it was easier to buy Watts. Also I put something on the boiler with self flushing feature. It gets its own hose to another drain bucket. It's never let out any water so I may be mistaken about it.
carpdad is offline   Reply With Quote
Tags
reducing valve watts rust
Pressure reducing valve chatter Roger0205 Plumbing 1 01-25-2016 08:49 PM
How to change a bad pressure relief valve maddog1 Plumbing 3 12-17-2012 12:46 PM
Is 15psi on boiler too low? vcsolit Plumbing 13 04-18-2012 10:34 AM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
