Waterproof P Trap Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By SeniorSitizen
  • 1 Post By Ghostmaker
Old 11-07-2016, 10:50 AM   #1
Rewards Points: 599
When installing a new P Trap, is any particular substance or material recommended on the threads of the two typically "knurled" parts that tighten up the assembly? When demo'ing old installations, I've noticed (at least it appears) that sometimes, the plumber has smeared some putty on the threads...
Curmudgeon10 is offline   Reply With Quote
Old 11-07-2016, 11:00 AM   #2
Rewards Points: 5,498
Re: Waterproof P Trap Fittings
I've never found it necessary on correctly assembled systems and to the best of my knowledge not recommended.
joecaption likes this.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Curmudgeon10 (11-07-2016)
Old 11-07-2016, 12:02 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,728
Senior is right imo also..... I've never needed or seen it. The threads really have nothing to do with the seal.
In a sense, it's a type of compression fitting between pliable plastics... make sure your washer is good and mating parts are clean... and firmly snug it up.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 11-07-2016, 03:44 PM   #4
Rewards Points: 1,852
I used to apply a touch of rector seal on the threads of a trap if a garbage disposal was being installed. Rector seal tended to make sure the nuts did not loosen.
MTN REMODEL LLC likes this.
The Following User Says Thank You to Ghostmaker For This Useful Post:
MTN REMODEL LLC (11-07-2016)
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Connecting brass trap to cast iron (Noob) acr2001 Plumbing 7 08-22-2012 12:37 AM
Would this be a 'P' trap or an illegal 'S' trap? klondiker Plumbing 7 04-06-2012 10:18 PM
Keep cast iron trap or new ABS trap? thebigsee Plumbing 1 01-26-2010 03:18 AM
No drain trap in a 7-year old home - is this normal? curls00 Plumbing 2 12-05-2009 12:40 PM
