Water Trap In Basement Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-17-2015, 05:09 PM   #1
Rewards Points: 4
Water trap in basement drain
After we moved in to our house (20 yrs old) we noticed odors from the drain in the basement. When I opened it up it appears to not have a water trap at all. On the picture the right opening appears to go straight to the sewer system while the bottom one is clogged (i pulled out debris as far as I could with no end in sight).
Is the right opening supposed to be plugged and the other one making the water trap or is the whole trap just missing? The cover is just a flat cover.
friedtomatoes is offline   Reply With Quote
Old 11-17-2015, 07:31 PM   #2
Rewards Points: 582
40 yrs in the plumbing trade...never seen such a set up....where do you live..
Old 11-17-2015, 07:56 PM   #3
Rewards Points: 26
The hole to the right should be plugged. It is a clean out I believe so that it is easier to snake past the trap.
kc_fella is offline   Reply With Quote
The Following User Says Thank You to kc_fella For This Useful Post:
ben's plumbing (11-18-2015)
Old 11-17-2015, 08:06 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 162
Yep, that's what it is- a one piece floor drain with integral trap and 1.5" clean out .
Put a plug in there to stop the odor.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 11-17-2015, 08:55 PM   #5
Rewards Points: 4
This is in Kansas City.
Great, I'll just have to get the rest of the debris out first. Maybe I have to get an auger to get through it.
Old 11-20-2015, 09:58 AM   #6
Rewards Points: 1,602
mikegp is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Basement drain: No P trap bdgray Plumbing 2 04-20-2013 03:32 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
