Water Test - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2015, 10:32 PM   #1
Rewards Points: 24
Water Test
Hi:
Following clear indications, I start google for Miami Dade water Test and found a Private Company that offers water test free in exchange to "adequate" home water filters offer. I requested a test but when they call me, explained that they only test for biological discrepancies and hard water.
Also contact online to Miami-Dade Water and Sewer Department, and the answer was: We test for Chlorine Residual, Total Coliform, Turbidity and pH"
I will proceed w/ both test. My question, does these test will be enough to determine what class of equipment I need at home? If not, any recommendation?
Thanks/
Mecaniquito is offline   Reply With Quote
Old 10-27-2015, 11:30 PM   #2
griz's Avatar
Rewards Points: 572
Find an independent private lab to provide the test.
One that isn't selling anything....
griz is offline   Reply With Quote
Old 10-28-2015, 12:56 AM   #3
Rewards Points: 24
Hi Griz:
Any tips? Google was not of much help.
Old 10-28-2015, 06:08 PM   #4
Rewards Points: 1,848
Call your local health department the environmental side is usually responsible for the wells. They should have water test labs.
or use the mail::
http://www.ntllabs.com/Merchant2/mer...Code=Homeowner
Ghostmaker is online now   Reply With Quote
Old 10-30-2015, 07:03 AM   #5
Rewards Points: 24
Hi:
I have Water Test results:
-A renamed Private company sent an specialist and performed what I will call a "colorant drops" hardness water test: 9 gpm. They recommended me their "Softener Station" that uses Salt, electricity and $.
-County's Water management told me that the Water I receive left the Station w/ values of 80 mg/lt. They proposed and I was agree, to do an "Water Supply Flush" @ home's water inlet.
Any thoughts?
Many Thanks
Old 10-30-2015, 09:24 AM   #6
Rewards Points: 127
We have environmental companies that don't sell anything so they I trust their judgment more than someone who sells water treatment systems .
jimn01 is offline   Reply With Quote
Old 11-05-2015, 06:02 AM   #7
Rewards Points: 24
Any Advice?
Originally Posted by Mecaniquito View Post
Hi:
Any thoughts?
Many Thanks
These were the water test results (9 gpm water test) and 80 mg/lt water management supply quality.
Should I install any kind of filter or device?
Old 11-05-2015, 07:44 AM   #8
GrayHair's Avatar
Rewards Points: 1,436
I agree with griz and Ghostmaker, but I have not figured out your concern(s). Are you concerned about your water's taste, hardness, clarity, purity, etc?
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
Old 11-05-2015, 10:55 AM   #9
Rewards Points: 24
Hardness is my concern.
I render valve leaking frequently.
Rgds
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
