Water Started Leaking From A Drain Cock - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-29-2016, 05:53 AM   #1
Rewards Points: 105
Water started leaking from a drain cock
Hi,
I just found that water is leaking from a drain cock of a water shut off valve in my basement. It is almost 30 years old valve, but I never had a problem with it. It controls water that goes outside, to my backyard.
Usually, I close the valve before winter and turn it on after winter is over. I did same thing this year. I shut water off in November and I turned it on two weeks ago. Yesterday I found that the drain cock is wet and water is slowly dripping from it. I tried to tight the cock and it got better. But it still very slow accumulates some water.
Replacing the valve would be difficult because of very limited space and lot of wood construction around it. Is there any way I can fix the problem without replacing the valve?
Thanks a lot for your advice.
sukhenkoi is offline   Reply With Quote
Old 05-29-2016, 06:09 AM   #2
Rewards Points: 18,776
Re: Water started leaking from a drain cock
Got a picture so we can see what your seeing?
Were's the valve leaking, at the stem, the threads?
r0ckstarr (05-29-2016)
Old 05-31-2016, 06:30 AM   #3
Rewards Points: 105
It was leaking at the drain cock. Every two-three seconds it was producing a water drop. I tightened it a little more and it stopped leaking.
But I am still thinking about replacing the entire valve. Do I need to do that or can I just fix it. It was never leaking before and I never touched the drain cock before. Why it suddenly start leaking after I turned on the valve?
I am sorry, but I don't know how to attach picture.
Mine looks like the one here:
http://www.homedepot.com/p/1-2-in-St...5012/206827974
Thanks.
Old 05-31-2016, 06:49 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
The washer under the cap is worn out. Replace the cap.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 05-31-2016, 05:05 PM   #5
Rewards Points: 1,856
Packing for valve
http://www.homedepot.com/p/DANCO-3-3...0793/203193511
Remove handle
Turn house water off
Drain at lowest sink
Remove nut under handle
Clean crap out under nut
Install the packing and tighten.
Ghostmaker is online now   Reply With Quote
Old 05-31-2016, 07:07 PM   #6
Almost always that type valve is going to leak at the stem if it's opened or closed after not being used for many years.
If it's not leaking after tightning up the packing nut then leave it.
Old 05-31-2016, 07:19 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
I don't think he is talking about a stem leak. I think he is talking about the cap that removes to drain the down steam section of pipe.
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Ghostmaker (06-01-2016), TheEplumber (05-31-2016)
Leaking plastic drain valve on water heater mystic_cobra Plumbing 11 06-23-2015 04:41 PM
Leaking drain valve in hot water heater rhelfand Plumbing 7 12-07-2012 04:37 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Water heater drain pan - can I drain into the washer drain? cjartguy Plumbing 7 04-15-2009 02:34 PM
