Water Softner - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2016, 05:31 PM   #1
Rewards Points: 2
water softner
constantly discharges
Mark Wilson is offline   Reply With Quote
Old 03-30-2016, 09:13 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 1,720
Re: water softner
The description of your problem is a tad thin. It could be plugged passages in the meter body or, more likely, either part of the mechanism has seized and/or a gear has stripped. Many of the gears in those things are plastic and can fail from wear or resistance. Can you hear the clock motor running and possibly a clicking sound? You can either start replacing parts or the whole meter assembly or call a tech. The same thing happened to me a few months ago but it was still on warrantee. A small part had seized (forget which one) causing a gear to strip.
lenaitch is offline   Reply With Quote
Salt based water softeners destroy septic? JPCheslock Plumbing 14 09-15-2015 08:13 AM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
