Water Softener Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2016, 09:00 AM   #1
Rewards Points: 18
Hi,
We bought a house a couple of years ago (in Florida) that's in the country. We have a water softener that sits outside. When we moved in, inspectors told us it wasn't working, and due other projects + life + laziness, until now I never got around to looking at it.
Turns out it does work. However, I noticed whoever installed it they just have the discharge hose lying on the ground. No air gap and there isn't a drain that I am aware of for it to discharge into. Obviously I can get it off the ground, but what about where it drains to? I mean, we do love in the country, but I assume just letting it run wild is not the way to go. Also, we have well water, probably about 30 feet from the softener.
I saw this as a possible solution on another forum. Thoughts?
Take a 4 inch corregated pipe that you can put a drain sock on ( looks kinda like panty hose) The corregated pipe has holes in it. We would cut about 5 foot of this and bury it in gravel with the drain sock on the pipe. Leave about a foot above ground with a cap on it. Drill a hole in the cap and drop the discharge hose in. That way water gets out put nothing gets in to stop the flow of water. All this is available at Lowe's or Home Depot. If you dig your hole deep enough you won't have any dead grass. Hope this helps.
seethesun is offline   Reply With Quote
Old 04-17-2016, 01:40 PM   #2
Rewards Points: 198
Re: Water Softener Drain
Originally Posted by seethesun View Post
Hi,
Take a 4 inch coragated pipe that you can put a drain sock on ( looks kinda like panty hose) The coragated pipe has holes in it. We would cut about 5 foot of this and bury it in gravel with the drain sock on the pipe. Leave about a foot above ground with a cap on it. Drill a hole in the cap and drop the discharge hose in. That way water gets out put nothing gets in to stop the flow of water. All this is available at Lowe's or Home Depot. If you dig your hole deep enough you won't have any dead grass. Hope this helps.
This will not solve the salt problem. I would consider running a pipe without holes at least 50 feet (if possible) from your well area then attach a 10' pipe with holes and a cap on the end and gravel as discussed above to preserve your drinking water from salt. Good luck
srloren is offline   Reply With Quote
Old 04-17-2016, 09:09 PM   #3
Rewards Points: 19,008
One of mine just runs under ground in a PEX line to a pit I dug out 24" deep and 24" wide and back filled with stone and covered with top soil.
Grass has never been effected, and it's far less then 15' from the well with no ill effects.
Been that way for at least 10 years.
Old 04-18-2016, 02:39 PM   #4
Rewards Points: 18
Thanks. I appreciate the responses.
water softener leaking only in winter Photogd Plumbing 6 11-14-2015 05:31 AM
Water Softener - Help with Proper System Selection badsha Plumbing 2 06-09-2014 12:02 PM
Water softener drain question theycallmehawk Plumbing 4 05-27-2014 10:42 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Drain for Water Softener... Mr Ron Plumbing 9 10-04-2010 12:44 PM
