Water Softener Drain ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2016, 05:08 PM   #1
Rewards Points: 14
water softener drain ?
My softener drains into a basin right next to it. I want to know if you can go strait to the drain inlet right above where the pump pumps it into sewage drain./?
freezeradio is offline   Reply With Quote
Old 03-29-2016, 10:08 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,064
Re: water softener drain ?
Ayuh,..... Ya can drain it into the basin, so it's on the suction side of the pump, not into the pump's outlet line,.....
Bondo is online now   Reply With Quote
Old 03-29-2016, 12:17 PM   #3
SHEPLMBR's Avatar
Rewards Points: 178
As long as you are not on septic.
SHEPLMBR is offline   Reply With Quote
water softener leaking only in winter Photogd Plumbing 6 11-14-2015 05:31 AM
Water Softener - Help with Proper System Selection badsha Plumbing 2 06-09-2014 12:02 PM
Water softener drain question theycallmehawk Plumbing 4 05-27-2014 10:42 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Drain for Water Softener... Mr Ron Plumbing 9 10-04-2010 12:44 PM
