Water In Sewer Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2016, 07:09 AM   #1
Rewards Points: 14
Water in Sewer Line?
This might be a very dumb/amateur question, but is there supposed to always be water in the sewer line?
For example, if I open up the clean out going to the city line from my house, you can clearly see a stream of water (not moving unless you flush).
Is this normal or is it supposed to be dry until you flush a toilet or drain elsewhere, etc?
As an added note, if I pour water in my vent on my roof, it clearly sounds like it's pouring into existing water.
Normal?
TiredDigger is offline   Reply With Quote
Old 04-15-2016, 08:30 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,572
Re: Water in Sewer Line?
Some places have a whole house trap. In those cases you will have water in the trap. Otherwise it is not normal to have water laying in the pipes.
Old 04-15-2016, 09:08 AM   #3
Rewards Points: 14
I live in Dallas and the house was built in 1957. Does that shed any light on how it might have been designed?
Old 04-15-2016, 11:17 AM   #4
Property Mgt/Maint
Rewards Points: 8,184
Any main clean out that I have opened has always had a little fluid in it. I always assumed it was from the solids floating down in stages with every rush of new fluid. But until the solids reach the end of any lateral it could cause a small amt fluid to reside in the line.
Is the drain operating properly? Was there a need to pull the clean out?
Yodaman is offline   Reply With Quote
Old 04-15-2016, 04:08 PM   #5
Property Mgt/Maint
Normal?
How much water are you talking about? A 1/4 or 1/2 inch wouldn't concern me. If the line is half full, I would say you have a blockage.
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
NEED ADVICE: Mystery water near sewer line tripower Plumbing 9 10-22-2013 11:31 AM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Hot Water Heater Problems Btabach Plumbing 7 05-21-2012 01:24 PM
Old water supply line a_lost_shadow Plumbing 7 04-19-2012 11:12 PM
