Water Quality Issue - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By jmon
Old 05-23-2016, 06:16 PM   #1
Rewards Points: 12
Question
Water Quality Issue
A little backstory:
I recently inherited the house that I grew up in, which was built in 1914, located in SE Victoria county, Texas. The house didn't have running water until the 1950s as far as I have been able to figure out, but my mother had a new water well drilled to 140' about six years ago (the old well casing had finally rusted through and collapsed).
I moved a new mobile home onto the property about three months ago to live in while the old house is being renovated. And I immediately noticed something odd: while the water in the old house is clean-smelling, the water in the mobile home has a sulfur smell to it.
Now, both properties are connected to the same well, the same pump, and the same tank. Neither has a water softener or filtration system. Why does the water in the mobile home smell like sulfur, then?
dal-designs is offline   Reply With Quote
Old 05-23-2016, 06:47 PM   #2
Rewards Points: 3,428
Re: Water Quality Issue
What kind of water heater is in the mobile home? Sometimes the water heater anode rod can be the culprit.
SHEPLMBR likes this.
jmon is online now   Reply With Quote
Old 05-23-2016, 07:23 PM   #3
Well water is usually more alkali then regular municipality water when not filtered, etc., and can react with the water heater anode rod causing that sulfur smell especially when using hot water.
I think your issue lies with the mobile home somewhere. Just my opinion. You could have other issues going on.
Tags
sulfur , water , well water
Radon soil gas, water w/radon, & other household air quality mitigation plans ylekyote HVAC 9 02-08-2016 03:46 PM
Salt based water softeners destroy septic? JPCheslock Plumbing 14 09-15-2015 08:13 AM
First time home owner Ė furnace/hot water issue rjohnson84 Plumbing 17 12-20-2010 10:40 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
