Water Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2010, 03:15 PM   #1
water pump
when my pump clicks on it runs fine when it shuts down it makes a loud thumping noise
kwik is offline   Reply With Quote
Old 12-31-2010, 03:52 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,240
Ayuh,... What kinda water pump,..??
describe your system....
Bondo is online now   Reply With Quote
Old 10-24-2015, 08:21 AM   #3
Rewards Points: 4
I am now experiencing much this same noise at the end of the cycle. Maybe closer to a growl coming directly from my above ground (in the basement) pump. This after replacing the D-tank back in April, but only recently started sounding off.
The system is energized by a Flint-Walling m/n 92U105A pump and seems a tad noisier than this time a year ago.
Thanks.
Gladog is offline   Reply With Quote
Old 10-24-2015, 09:17 AM   #4
Rewards Points: 3,432
It may not be your pump. It may be the check valve. They can be noisy.
As mentioned, please describe your pump a little more. Manufacturer and model number would help, and a picture of your set-up. Thanks.
jmon is online now   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
pool pump fill then dumps water nanderson360 Plumbing 2 10-14-2010 10:58 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 08:01 AM
