Water Pressure Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2017, 10:44 PM   #1
Rewards Points: 50
water pressure tank
Need to repipe copper lines from pressure tank to water heater. The tank is already there it is not a new installation. It is an wellxtrol tank. After letting water drain out of tank and reconnecting copper pipes to water heater will the tank fill up and work without adjustments? Does the tank need to be recharged or other adjustments. Thanks.
casio10 is offline   Reply With Quote
Old 04-18-2017, 10:55 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,940
Re: water pressure tank
There should be no adjustments needed. You might need to prime the pump to get the water flowing, depending on how your system is set up.
Old 04-18-2017, 11:04 PM   #3
Rewards Points: 6,378
Ideally, the tank won't need any adjustments other than would be because of possible temperature change but that is so minuscule we shouldn't be concerned. But on the other hand, if you have a tire pressure tester or other suitable gauge handy, as you know drained is the perfect time to check it.
Old 04-19-2017, 06:07 PM   #4
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
While there is no water in the pressure tank take a tire gauge and check the air in the tank and make sure that it is 2lbs below what the kick in point is for your switch.
30-50 28lbs of air
40-60 38lbs of air
Akpsdvan is offline   Reply With Quote
Old 04-19-2017, 06:37 PM   #5
Super Moderator
joed's Avatar
If everything was working properly before, then there are no concerns when you refill. Draining does not alter any of the previous settings.
Old 04-19-2017, 06:44 PM   #6
Water Treatment
Akpsdvan's Avatar
But it is ways good to check and make sure that the air pressure is correct and not slipping.
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
