Are Water Pressure Regulators Required? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
Old 10-15-2017, 09:04 PM   #16
Rewards Points: 6,152
Re: Are water pressure regulators required?
ron45 is offline   Reply With Quote
Old 10-15-2017, 10:07 PM   #17
Endless Projects
Rewards Points: 1,648
My plan tomorrow is to buy a pressure gauge and put it on the outdoor faucet that is the closest faucet to the pressure regulator. I will turn on another sink and adjust the regulator to see if I can get more pressure to my shower.
The other water sources like the sinks downstairs have lost some pressure, but it is deal-able. The shower is almost un-useable.
To me the install looks suspect. The Poly pipe that comes in is 1", it looks like it is stepped down to 3/4 pex, all the joiners in the pex look to have an even smaller diameter, maybe 1/2 inch. This goes into the 3/4 copper throughout the home.
Are the narrow connectors of the pex in the entry line creating a bottleneck in my water trunk line?
Photobug is offline   Reply With Quote
Old 10-15-2017, 11:42 PM   #18
Rewards Points: 6,566
Between down stairs pressure at the sink and upper level at the shower there will be about 4-5 pounds less pressure at the shower head because of elevation difference but that would be inconsequential in the 60-70 lb. range. With the shower being nearly un-usable I'm betting a debris problem, but if I loose that bet it wouldn't be the first.
Old 10-16-2017, 05:20 AM   #19
Naildriver
chandler48's Avatar
Rewards Points: 3,674
The neck down of the piping should not have happened. It won't affect "pressure", as it will be constant. You will get a good pressure reading. You will lose in "volume", which IMO is your problem. It should have been 3/4" throughout up until it turned up to the appliance using the water, then 1/2". Was this a recent install? If so, I would have the installer correct it showing him the error of his ways.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 10-16-2017, 06:08 AM   #20
Rewards Points: 2,074
Originally Posted by ron45 View Post
There's no reason to have water savers if the pressure keeps getting turned up.
Why take a chance with too high of water pressure.?
" Water savers suck"
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 11-15-2017, 06:27 PM   #21
Endless Projects
Just an update, the pressure regulator was clogged. The plumber did not suggest I drain the line before turning it on. They fixed it for free with the promise I use them for my next project which I did.
Old 11-15-2017, 07:14 PM   #22
Plumbers that will stay until the job is completed and correct are difficult to find. You must have hired the last plumber I fired.
Old 11-15-2017, 10:16 PM   #23
Endless Projects
Not only that, using him saved me on the next project saved me thousands. I had a bid for plumbing a bathroom addition that came in at $4250 for what was estimated as one days work. I negotiated with this company to send just one plumber at an hourly rate with me as the "apprentice". We finished the rough plumbing in one day at around $1300 including supplies which I put on my account. In the process I learned to do the PEX thing and am confident in doing all the finish plumbing and rough plumbing on the next bathroom I will be adding.
mark sr likes this.
High water pressure spike (140 PSI) sidejobjoe Plumbing 2 01-28-2015 04:06 PM
Watts Pressure regulator does not hold water pressure goshenplumber Plumbing 4 05-05-2013 09:54 AM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
Decreased water pressure in home Gordon07 Plumbing 3 12-03-2009 11:44 AM
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 12:04 PM
