Water Pressure Is Low In Kitchen Only?? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By SeniorSitizen
Old 09-09-2016, 10:20 AM   #1
Rewards Points: 194
Water pressure is low in kitchen only??
The water is working but seems to be coming out at half the strength in the kitchen faucet only. Bathroom sink and tub are fine. Any clues as to why this might be, how to locate the problem and fix it? Thanks
PS - not very handy but can check things out.
Jacke is offline   Reply With Quote
Old 09-09-2016, 10:35 AM   #2
Rewards Points: 5,642
Re: Water pressure is low in kitchen only??
Although the aerator screen doesn't actually affect pressure at that point, it does affect flow ( volume ) and it being a filter, that is often the first item suggested to check for restriction. It sometimes un-screws with difficulty if plumber's grease wasn't applied to the threads during assembly, and it usually isn't.
Old 09-09-2016, 12:06 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,754
Seniors place would be the first place I'd look....
(The second would be the angle stop valve... (by checking the flow rate directly out of the angle stop valve... you can at least determine if the restriction is in the faucet or not.)
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Jacke (09-10-2016)
Old 09-09-2016, 12:08 PM   #4
Rewards Points: 18
After taking the areator off, take it apart but lay each piece in a line so you know how to put it back together. The plastic part inside is usually 2 piece and if you take it apart you will typically find small mineral grains blocking up some of the holes, or even a piece of the rubber washer blocking the main hole. I would also recommend that, wher the aerator has been removed, put the stopper or strainer in the sink and turn both the hot and cold on full blast to bkow out any debris that might be in there. Sometimes the rubber washer doesnt come out with the aerator but will come out when you blow water thru. Worst case is to take the old one to home depot or lowes and buy a new aerator for a couple of bucks.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Hot water pressure low (pictures) bluefoxicy Plumbing 4 12-11-2012 07:45 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Low Water Pressure Only on Kitchen Faucet Chsmadden Plumbing 4 03-21-2010 09:01 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
