Water Pressure Decrease When New Dishwasher Was Installed - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By SeniorSitizen
Old 11-24-2017, 11:44 AM   #1
Rewards Points: 71
Water pressure decrease when new dishwasher was installed
Water pressure change after new dishwasher install
Hi there,This is my first time posting. I have just installed a new dishwasher as my old one was broken but I noticed that the water pressure on my kitchen Faucet has gotten much lower so it does not run as it used to since I installed the new dishwasher. The new dishwasher seems to be working fine. It was suggested that I check the aerator of the Faucet but Iím not sure where that is. I have attached some photos so can anyone tell me where I would find the aerator on my sink Fossett in the kitchen? Any advice would be helpful.Thank you,R
Water pressure decrease when new dishwasher was installed-db71692c-fc34-43f5-9e4a-4bfcdd14f9d6_1511545382060.jpg   Water pressure decrease when new dishwasher was installed-4ef5fe1a-3f08-492c-b200-045247638f4b_1511545404905.jpg
RichTibo is offline   Reply With Quote
Old 11-24-2017, 02:38 PM   #2
Rewards Points: 6,458
Re: Water pressure decrease when new dishwasher was installed
Usually where the water exits there will be a aerator screwed on that often partially plugs with debris when plumbing work is being accomplished. Made to unscrew but don't be surprised if that fails as plumber's water proof grease is seldom applied to the threads during installation.
Google aerator.
ron45 likes this.
Old 11-24-2017, 02:39 PM   #3
Rewards Points: 1,938
https://en.wikipedia.org/wiki/Faucet_aerator
It should unscrew by hand.
Old 11-26-2017, 02:04 PM   #4
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Let me under stand this, Dishwasher needed replacement.
Closed the hot line to the dishwasher and change the dishwasher?
Why did the cold to the sink get closed?
Either the close faucet or angle stop is not fully open or will need a replacement because it will not fully open any more.
Akpsdvan is offline   Reply With Quote
Old 11-27-2017, 11:50 AM   #5
custom user
Rewards Points: 1,820
You can get a rebuild kit for those valves but I'd put in some quarter turn ball valve shutoffs.
JasperST is offline   Reply With Quote
Water pressure problems maddog1 Plumbing 7 11-10-2014 05:37 PM
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
