Water Pressure Adjustment - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2015, 05:03 PM   #1
Rewards Points: 1,058
Water pressure adjustment
I finally got around to testing the water pressure on my "new" house.
It measures 63psi. My understanding is that it should be 55psi.
The pressure reducing valve is 8 years old, though for the first 6 years the water was off 8 months a year.
I figure the difference between 63 and 55 isn't all that much, and while adjusting it is just a matter of turning a screw, I don't want to get into any trouble. Sometimes when stuff hasn't been adjusted for 8 years, it can fail, and that would be difficult. They cleverly put all the entry valves behind a tiny access door in a finished wall, and replacing anything would be a challenge.
So, what advice do you have for me? (besides replacing the access door with one 4 times a big, so it is actually functional)
Toller is offline   Reply With Quote
Old 01-16-2015, 05:59 PM   #2
Civil Engineer
Rewards Points: 5,246
I would not touch it. There is nothing wrong with 63psi, that is the approximate upper limit of my well, it works fine. You are correct, if you haven't touched the pressure limiting valve in 8 years, there is a good chance it will not work correctly after you adjust it. Painful experience with valves is they all go bad eventually, if it works OK, probably best to leave it in peace.
Old 01-16-2015, 06:49 PM   #3
Rewards Points: 582
yep agree with dan its not broke ..don't fix it ...63 psi if good ....
Old 01-16-2015, 07:01 PM   #4
Rewards Points: 1,938
That's good pressure most toilets are good to 65LBS.
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Well Water Pressure Fluctuation cforbes Plumbing 13 10-01-2012 06:52 AM
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
