Water Meter Shows Leakage - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2016, 09:16 AM   #1
Rewards Points: 438
Water Meter shows leakage
Hello,
I recently noticed that my water meter (new) is showing slight water usage. After shutting down all water sources, I noticed that I am using about 6 gallons a day. The red leak detector doesn't spin constantly but tethers back and forth. I am able to measure water usage after observing for at least 3-4 hours based on the movement of the large needle.
I have performed leak test on all toilets and have no irrigation system. There are no visible signs of water leak inside and outside other than constant stream of water in my sump pump which I have confirmed with the city is not city water (flouride content etc.)
My water meter is located in the basement with the city main located about 50 ft outside.
Thoughts on what could be causing such a slight usage? I do have gas water heater with expansion tank and water circulation on timer.
Many thanks!
sbkim is offline   Reply With Quote
Old 08-11-2016, 09:27 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: Water Meter shows leakage
Are you sure it is not a toilet? How did you test them? Dye in tank is the best.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 08-11-2016, 09:34 AM   #3
Rewards Points: 1,256
Leak at the boiler? Boiler and the radiators may have air trap things (looks like a barrel) that can leak, although probably not 6 gl a day. I have a auto water feeder or a pressure reducer for 2 boilers that has some sort of suto clean valve with its own hose going into bucket. Maybe that can leak? Checked and verified every inch of piping?
This is for the pros but hot water pressure too great and hot water back feeding into cold water line and tricking the meter into registering water movement?
carpdad is offline   Reply With Quote
Old 08-11-2016, 10:22 AM   #4
Rewards Points: 438
I have no boiler.
Initially I thought may be water supply lines to my basement bathroom could be leaking and thus water in my sump pit. However, I believe the supply lines are running above the basement floor.
Old 08-11-2016, 10:22 AM   #5
Rewards Points: 4,746
Not sure what this means but I would close all shut off valves in the house if you have not already.
Where do your water lines run - are they visible within the house or are they run through a slab for any distance?
stick\shift is offline   Reply With Quote
Old 08-11-2016, 10:23 AM   #6
Rewards Points: 438
Yep, did the dye test and none of them are leaking.
Old 08-11-2016, 10:26 AM   #7
Rewards Points: 438
Sorry for not being clear but I mean I turned off water. I have not closed all shut off valves. I seem to have 2 of them near the meter - one closest to the wall (entering from the street) and another after the meter. I presume if I shut the water off, technically the meter should not run at all unless faulty.
Water line comes from the street into basement:
street ----> basement (water meter) ----> throughout the house
Old 08-11-2016, 10:41 AM   #8
There aren't shut off valves under the kitchen sink and the toilets and such? Those were the ones I meant, just assumed you had more than the main valves.
Old 08-11-2016, 10:50 AM   #9
Rewards Points: 438
Good point. I guess I can go around and close all valves in the kitchen and bathroom and then re check...
Is there any benefit to turning off the valve at water meter just to confirm that the meter is not faulty?
Old 08-11-2016, 11:42 AM   #10
At this point I would be considering every option you can think of to try.
Old 08-11-2016, 11:45 AM   #11
Rewards Points: 438
I was pleasantly surprised that city was willing and able to come into help locate the leak but I'd like to rule out the obvious. thanks
Old 08-11-2016, 03:51 PM   #12
hkstroud's Avatar
Rewards Points: 6,684
In my opinion the best way to check for a leaking toilet is to hold down the float mechanism until water flows out the over flow pipe, then turn off the stop valve under the tank.
Come back some time later. From 15 minutes to hours later. If the water level is not still at the top of the over flow pipe you have a leak. If the water level is still at the top of the over flow pipe you don't have a leak. Extremely accurate and gives you some idea of how bad the leak is. No looking for dye or food coloring and no question of is the water in the bowl a different color or not.
hkstroud is offline   Reply With Quote
Old 08-11-2016, 04:13 PM   #13
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Unless the stop valve is leaking. And it is common with old valves.
Old 08-11-2016, 05:08 PM   #14
hkstroud's Avatar
Nope, even if stop valve leaks the fill valve won't fill tank back up to the level of overflow pipe. For that matter you really don't have to turn off stop valve. Just makes you feel better to do so. Just hold fill valve down until water flows out the overflow. Come back later. If water level is not at top of overflow you have a leak.
Water system noise in house, help wanted lkustb Plumbing 3 09-01-2015 09:18 AM
water leakage and condensation cecelia65 Building & Construction 12 07-25-2013 02:23 AM
Connect Meter For Temporary Water To Trailer TheGriff Plumbing 11 09-11-2012 10:17 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
