Water Main Depth? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2016, 10:44 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 18,412
Water Main Depth?
I have a 3/4" water line feeding my house.
I'm making some 'modifications' to the front of the house and with the removal of a big plant that was more or less hiding the incoming line.
It now comes up about 2.5' from the house to about a foot above the dirt...then goes into the house.
I'd like to reduce that exposure. I've started digging and I'm down about 1.5 and no sign of the vert run.
How far down do you think it will be?
ddawg16 is online now   Reply With Quote
Old 12-16-2016, 11:48 AM   #2
JUSTA MEMBER
Rewards Points: 3,778
Re: Water Main Depth?
Since there's no frost line in So. Cal, I will speculate , no farther than 4 feet.
Your city office should have a good idea.
ED
de-nagorg is online now   Reply With Quote
Old 12-16-2016, 12:13 PM   #3
Rewards Points: 1,054
Code in FL is 12" deep.
clarenceboddick is offline   Reply With Quote
Old 12-16-2016, 12:17 PM   #4
JOATMON
ddawg16's Avatar
Thanks guys...
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 07:46 AM
