Water Line Too Deep - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2016, 11:02 AM   #1
Rewards Points: 34
Water Line too Deep
Inspector making me put in a water pressure reducer. An older house so must put it in near meter. The water line is 42" below surface. I consulted a plumber he said putting in some elbows to bring it closer to the surface will not hurt water flow very much. The other solution is to get a skeptic tank type enclosure to go that deep. FYI.
tim999 is offline   Reply With Quote
Old 04-25-2016, 11:54 AM   #2
Rewards Points: 3,492
Re: Water Line too Deep
Welcome to the forum Tim.
Must be the way everything was set-up back then. Idk. Seems like the inspector and plumber from your area would know the best solution.
Please wait for the plumbers to respond, they may be able to help you further.
jmon is offline   Reply With Quote
Old 04-29-2016, 07:16 AM   #3
Rewards Points: 1,538
The way I did was to put it after the meter. I'm not a plumber and don't know any rule about how it should be done. But if reducer goes before the meter, you're being asked to protect the meter - which sounds like it's the water company's job.
BTW, a gauge on the outlet side is a must for adjustment.
carpdad is offline   Reply With Quote
Old 04-29-2016, 08:27 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 900
New one on me. To me they belong in the house, basement or utility room. Can't imagine why you would bury it.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 04-30-2016, 04:36 PM   #5
Rewards Points: 34
the PRV is in a hole in the ground because there was no other place to put it. It has a cover over it. Lift the cover and you have access to the PRV.
Tags
deep , water line deep
Water line running through garage drywall physdl Plumbing 6 07-09-2015 08:50 AM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
