Water Levels In Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2016, 09:30 PM   #1
Rewards Points: 422
Water levels in toilet
My daughter says when she flushes the toilet, the water in the bowl is way too high, after it fills. And the water slowly drains out of the bowl to where it's almost empty. This sound like a clog, correct? Any other possibilities?
Thanks.
Jim McC is offline   Reply With Quote
Old 05-06-2016, 09:42 PM   #2
Rewards Points: 18,794
Re: Water levels in toilet
That would be my first guess.
Septic tank full, blocked vent, clogged filter in the septic tank, failed leach field.
All other things it could be.
If it's city sewer a few of the other items do not apply.
Old 05-06-2016, 11:39 PM   #3
Rewards Points: 422
Thanks. It's a city sewer. She's been plunging it, but she can't fix it. Any other advice if it is a clog?
Old 05-07-2016, 07:07 AM   #4
Rewards Points: 3,286
High priority item to check -- Drain pipe vent (stack vent) to the roof.
If this is clogged then the toilet(s) will behave unpredictably.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 05-07-2016, 01:09 PM   #5
Rewards Points: 422
Thanks. How would that get clogged?
Old 05-07-2016, 08:17 PM   #6
Property Mgt/Maint
Rewards Points: 8,184
birds
Yodaman is offline   Reply With Quote
DIY Tips and Tricks! DangerMouse General DIY Discussions 171 09-04-2015 09:50 AM
Toilet: water supply hose won't let water through. alathena Plumbing 7 08-15-2014 03:26 PM
Disturbing toilet water releases sewer gas mrgrey Plumbing 8 08-07-2014 07:15 PM
Main Toilet Supply Line Clogged? Redskins-21 Plumbing 10 01-27-2014 05:27 AM
Water draining into toilet bowl but not from tank black00 Plumbing 6 09-19-2012 08:28 PM
